Scooter vs Motorcycle: The Real Differences, With Current Prices
- on October 12, 2026
A scooter has a step-through frame and an automatic transmission you twist and go. A motorcycle has a straddle frame and, usually, a foot shifter. Engine size does not separate them: we list 150cc scooters and 140cc motorcycles. Buy the scooter for errands and short commutes. Buy the motorcycle if you want to learn to shift.
Scooter vs motorcycle: what is actually different
Forget the badge on the tank. Four things decide how each one feels, and you can check every one of them on a listing before you buy.
- •Frame. A scooter has a flat floorboard. You step through and sit with your feet together. On a motorcycle you swing a leg over a tank and your knees grip it.
- •Transmission. Most scooters use a CVT: a belt running between two pulleys, no gears, no clutch lever, no shift pedal. Motorcycles use a gearbox and a chain. Some, like the PBZ125-2 below, are semi-automatic: you still tap a foot shifter, but there is no clutch lever to work.
- •Storage. Scooters carry things. The Zoom 150 lists a locking trunk, and the Tao VIP 50 has under-seat storage. Motorcycles carry nothing unless you bolt something on.
- •Wheels. Scooter listings run 10- to 14-inch rims. That sounds like a clean dividing line until you read the Ice Bear Fuerza, a manual-shift street bike on 12-inch rims. The Cafe 140 sits on 17-inch wheels and looks like a motorcycle all day.
Is a scooter a motorcycle? Mostly a question for your DMV
Mechanically, no. Legally, it depends on where you live. States draw the line between moped, scooter and motorcycle in different places, and engine size is the usual yardstick but not the only one. Do not assume a 150cc scooter and a 150cc motorcycle are treated alike, and do not assume they are treated differently. Call your DMV with the engine size in hand before you pay.
We cover the license side in more detail in our guide to scooter and moped licensing and the moped question in moped vs scooter. For California, look for the CARB or CA Legal wording in the listing title. It is there when it applies.
Scooter vs motorcycle prices: what we list today
| Model | Type | Engine | Transmission | Price |
| Vitacci Zoom 150 | Scooter | 149.6cc | CVT automatic | $999 |
| Tao Pilot 150 | Scooter | 150cc | CVT automatic | $1,099 |
| Tao Tank 200 | Scooter | 175cc, EFI | Automatic | $1,299 |
| TrailMaster Turino 200 | Scooter | 168.9cc | CVT automatic | $1,499 |
| RPS Cafe 140 | Motorcycle | 140cc | 2-speed automatic | $979 |
| Ice Bear PBZ125-2 DLX | Motorcycle | 125cc | 4-speed semi-automatic | $1,249 |
| Vitacci Falcon 200 EFI | Motorcycle | 168cc, EFI | CVT automatic | $1,999 |
| RPS Condor 150 | Motorcycle | 150cc | 5-speed manual | $1,349 |
| Vitacci GTX 250 EFI | Motorcycle | 223cc, EFI | 5-speed manual | $2,199 |
| RPS Cross Country 300 EFI | Motorcycle | 302.5cc, EFI | 6-speed manual | $2,999 |
Live Motobuys listings, active and in stock as of October 12, 2026. Engine and transmission read from each product title. Prices change; the product page is the final word.
The overlap is the interesting part. The RPS Cafe 140 is a motorcycle and costs less than the Zoom 150 scooter. The Falcon 200 EFI has a motorcycle's 17-inch front wheel and a CVT, so it has no shifting at all. If you came here thinking the choice is cheap scooter or expensive motorcycle, the listings say otherwise.
Browse the full range in our scooters, mopeds and trikes collection or the street bikes, dual sports and enduros collection.
Which should you buy?
If you have never ridden, buy the scooter. It is not that scooters are safe and motorcycles are not. It is that a scooter removes the one skill that trips up beginners, coordinating a clutch and a shifter at a stop sign, so you can learn traffic first.
Buy the motorcycle if you want the shifting. The Condor 150 is a five-speed manual with a 31-inch seat height in its title, and that is a real learning bike: small enough to hold up, honest about every mistake you make with the clutch. If you want the motorcycle look without the lever, the Cafe 140 and the Falcon 200 EFI are the two to compare.
Not sure which side of the line a bike falls on? Our piece on automatic and semi-automatic motorcycles sorts them, and cheap beginner motorcycles covers the budget end.
What breaks, and what to check before the first ride
These are entry-priced machines, and the wear points are predictable. On a scooter it is the drive belt and the rollers inside the variator. They wear with use, and the first sign is a scooter that revs but pulls slowly. On a motorcycle it is chain slack and clutch adjustment, both of which loosen in the first few rides.
One detail that catches people: the Fuerza spec calls for motorcycle oil with a clutch additive. Wet-clutch bikes can slip on the wrong oil, so do not pour in whatever is on the shelf. A CVT scooter has no such clutch, so the rule does not apply there.
Before any first ride, check tire pressure, charge the battery and look over every bolt the crate left loose. If you would rather not do it yourself, many models have an assembly option; see our assembly-available collection. Questions go to our Garland, TX team on 877-667-6289.
Scooters that look like motorcycles
The RPS Cafe 140 and the Vitacci Falcon 200 EFI are the closest. Both have 17-inch front wheels and a motorcycle stance. The Cafe 140 is a 2-speed automatic and the Falcon 200 EFI is a CVT automatic, so neither needs a clutch lever.
Do you need a license to drive a moped
It depends on your state and on the engine size. We cannot give one answer for every state, so check with your DMV before buying. Our scooter and moped licensing guide explains what to ask.
Highway legal moped
That is set by your state, not by the vehicle. Ask your DMV about road and speed restrictions for your engine size before you buy, and do not rely on a listing alone.
150cc scooter under $1000
As of October 12, 2026, the Vitacci Zoom 150, Vitacci Milano 150, Vitacci Fighter Pro 150 and RPS Adventure 150 all list at $999 and are in stock.
How much is a scooter
Gas scooters from 50cc to 200cc on our site currently list from $699 (the Gator 50-S3) to $2,399 (the Ice Bear Vlad 200). Three-wheel trikes cost more.
Three to look at
Not sure which fits? Call 877-667-6289 and tell us how you plan to ride. Prefer to look first? Start with the scooters or the street bikes.
