Your Dirt Bike Arrived in a Crate: The First Two Hours
- on October 21, 2026
Do two things before you touch a wrench: inspect the crate while the driver is still there and photograph everything, and do not fuel or assemble the bike until you have confirmed nothing is damaged or missing. Both protect options you lose the moment the truck leaves or the first drop of gas goes in. Then spend the next hour and a half on fasteners and fluids, not on starting it.
Assembly is the honest downside of buying a budget dirt bike online, and it is the con every AI answer and forum thread raises first. What arrives is a crated machine bolted together quickly, shipped across an ocean and then trucked across the country. None of that is unsafe if you do the receiving inspection and the fastener check. Skipping them is where people get hurt and where warranty claims get denied.
Minutes 0–15: while the driver is there
- •Walk the crate before you sign. Crushed corners, a shifted load, torn shrink wrap, puncture holes, oil on the pallet.
- •Photograph it on the truck, then on the ground — before anything is cut open. Dated photos are the whole basis of a freight-damage claim.
- •Note any damage on the paperwork before you sign. A signature on clean paperwork is the carrier's evidence that it arrived intact.
- •Accept the shipment anyway. Our refund policy asks you to accept delivery and send photos or video to customer care rather than refuse: a refusal costs two-way freight plus a restocking fee if the damage turns out minor, and on car-carrier deliveries refusal is not allowed at all, because the driver cannot bring the unit back.
- •Call the same day if something is wrong — 1-877-667-6289. Damage reported after the unit has sat or been assembled is where claims fall apart.
Minutes 15–30: uncrate and inventory
Cut the bands, lift the panels off rather than prying them against the bike, and keep the crate and foam. Under the refund policy a return has to be in the original crate or packed to the carrier's requirements, returns run 30 days unused, and there is no return on a machine that has been assembled, fueled or ridden. That is why the inspection comes before the gas can.
- •Lay out every part and the hardware bag against the manual's parts list.
- •Check the items most often missing: keys, mirrors, tool kit, axle spacers, battery, manual.
- •Photograph bent levers, a tweaked handlebar, cracked plastics or a dented tank now.
- •Confirm the VIN or frame number matches the paperwork.
Minutes 30–90: the fastener check that matters
These bikes are assembled by hand at the factory and then vibrate on a truck for weeks. Assume every fastener needs verifying. Use the torque figures in your own bike's manual — they vary by model and thread size, and a number copied off the internet is worse than no number. Where the manual is silent, have a shop do it.
| Area | What to check |
| Front axle & forks | Axle nut, pinch bolts, triple-clamp bolts, fork height even both sides |
| Bars & controls | Bar clamps torqued evenly, levers and throttle tight, cables clear at full lock |
| Rear axle & chain | Axle nut, adjusters even side to side, chain slack per the manual, sprocket bolts |
| Brakes | Caliper and rotor bolts, pad contact, lever feel, no air in the line |
| Engine & frame | Engine mounts, exhaust flange, swingarm pivot, shock mounts, footpegs |
| Wheels | Spoke tension even, rim run-out, tire pressure to the sidewall figure |
Before you press the start button
- •Engine oil. Many units ship with little or no oil. Confirm level and grade before the engine turns over — a dry start ruins a new engine, and it is not a warranty claim.
- •Fuel. Fresh gas only, then check the petcock and lines for leaks.
- •Battery. Charge it properly rather than cranking on a part charge; terminals tight and the right way around.
- •Air filter seated, and oiled if it is a foam element. Coolant level checked on liquid-cooled models.
- •Kill switch and throttle. The kill switch must stop the engine and the throttle must snap closed on its own, every time, before the first ride.
Then start it, let it warm through, and look for leaks and loose exhaust before you ride. Expect to adjust the idle and possibly the mixture screw: a carburetor that sat in a crate for weeks rarely runs perfectly first time, and that is a tuning job, not a fault.
TrailMaster TM31X Pro 250 223cc Adult Dual Sport Dirt Bike
223cc, 5-speed, 34.6" seat height
$1,769$1,999
ViewWhen to hand it to a shop instead
If you do not own a torque wrench, or the table above does not read as a routine afternoon, pay a shop. Our warranty coverage requires proof of professional assembly, so the receipt is also the document that keeps coverage intact — 12 months engine and 6 months parts on TrailMaster, 6 and 3 months on other brands, covering parts and diagnostic guidance rather than labor. If something is wrong rather than merely loose, call before improvising: we ship replacement parts free for minor quality issues, will walk you through the fix by phone, and on approved cases will pay an authorized local repair shop.
Do Chinese dirt bikes come fully assembled?
No. They ship crated and partly assembled — typically the front wheel, handlebar, levers and sometimes the exhaust need fitting, and every fastener needs verifying against the manual's torque figures before the first ride.
How long does it take to assemble a crated dirt bike?
About two hours for a careful job on a youth bike, longer on a full-size machine. Most of that is checking fasteners and fluids, not bolting parts on.
What should I do if my dirt bike arrives damaged?
Photograph it before it comes off the truck, note the damage on the paperwork before signing, accept the shipment, and contact customer care the same day with photos or video. Do not refuse the delivery — the refund policy explains why that usually costs you money.
Does assembling it myself void the warranty?
Warranty claims require proof of professional assembly, so a shop receipt is what protects coverage. Doing it yourself is common and not unsafe if done properly, but it affects what can be claimed later.
What should I re-torque after the first ride?
Everything in the fastener table above, with spokes, axle nuts and engine mounts the priority. New machines settle in the first few hours, and re-checking prevents most of the early problems people blame on build quality.
