Are Chinese Dirt Bikes Reliable? An Honest Answer From a Dealer
- on October 21, 2026
Chinese-built dirt bikes are reliable enough to be worth the money, and not as reliable as a Honda or a Yamaha. Engines and frames generally hold up. What fails is the small stuff bolted to them — fasteners, chains, cables, carburetors, electrical connectors — and nearly all of it is cheap and quick to fix. We are a dealer, we have sold these machines since 1989, and that is the honest version.
Almost everything in our dirt bike and pit bike catalog is built in China and sold under a US brand: Apollo, Tao, TrailMaster, RPS, Vitacci. Below is what we see come back, what never does, and when we would tell you to buy something else.
What actually breaks
Failures cluster in two places: fasteners that were never torqued correctly at assembly, and wear items specified to a budget. The engine bottom end and the frame are rarely the problem.
| Area | What we typically see | Rough cost to fix |
| Fasteners | Bolts backing out in the first few hours — sprocket, engine mount, bar clamp, axle. The most common cause of a bike that “broke”. | A torque wrench and thread locker |
| Chain and sprockets | Stretch and misalignment early if never adjusted after break-in. | $30–$90 for a set |
| Carburetor | Gummed jets after the bike sits with fuel in it. | $25–$60, or a cleaning |
| Electrical | Loose connectors, kill switches, cheap starter relays. EFI models see far less of this. | $15–$70 per part |
| Plastics and controls | Levers, mirrors, fenders — cosmetic, and they break in a crash on any bike. | $10–$50 |
| Engine internals | Uncommon when oil changes are done on schedule. | Expensive — so do the oil |
Notice what is not on that list: catastrophic, unfixable failure. The machines that genuinely die young are usually the ones run on the factory oil for a season with nothing ever re-torqued.
What a $900 bike buys, and what it does not
Six hundred to twelve hundred dollars gets a real four-stroke engine, a steel frame, working brakes, and a machine that will do backyard and trail riding for years if maintained. For a kid learning to ride, or an adult who wants a bike on the property, that is often the correct purchase.
It does not buy race-grade suspension, tight manufacturing tolerances, a service department in every town, or resale value. Budget suspension is fine on trails and out of its depth on a motocross track.
Reliability is not the same across brands
Treating “Chinese dirt bikes” as one product is the main buyer mistake. Apollo and TrailMaster run the deepest lineups; RPS is where the street-legal dual-sports live; Tao is squarely entry and youth. The brand-by-brand breakdown is here. Worth knowing: TrailMaster is a brand of BV Powersports, a US company — “BV” stands for Best Value. BV designs and specs the machines, has them manufactured in China, sells through authorized US dealers (we are one), and runs its own parts department. That is a different situation from an unbranded bike off a marketplace listing.
Bikes we stand behind
TrailMaster TM11 107cc Youth Dirt Bike
110cc youth, fully automatic — a sensible first bike
$659$829
Apollo DB-X19 125cc Youth Dirt Bike
125cc, 17" front, manual — the classic step-up pit bike
$899$1,019
TrailMaster TM31 Pro 250 223cc Adult Dirt Bike
250-class, 5-speed, 34" seat — adult trail riding
$1,649$1,899
TrailMaster TM38E 298cc Adult Dirt Bike
298cc EFI, electric start — top of our range
$3,399$3,749
ViewPrices and stock change. Browse Dirt Bikes & Pit Bikes, Kids Dirt Bikes, or everything under $1,000.
Four things that decide whether yours lasts
- •Assemble it properly, or pay someone who will. These ship in a crate roughly 85–95% assembled, and the rest is where most “defective bike” stories start. Our warranty requires professional assembly for that reason. Receiving and first-start checklist.
- •Re-torque everything after the first ride, then the next two or three. Factory torque on budget machines is inconsistent. Checking bolts is free and prevents most early failures.
- •Change the oil early. Dump the factory fill after the first couple of hours, then follow the manual.
- •Line up parts access before you need it. A dealer with a parts department is a different proposition from a seller who vanishes. What parts support actually looks like.
The same logic covers the rest of the catalog, though quads and karts fail differently — driveline and steering rather than fasteners. Covered separately here, alongside the ATV and go-kart ranges.
Where we stand behind the machine
Engine warranty: 12 months on TrailMaster, 6 months on other brands. Parts warranty: 6 months on TrailMaster, 3 months on other brands. It covers parts and diagnostic guidance, not labor, and requires professional assembly. For minor quality issues we ship replacement parts free and give phone tech support, and on approved cases we pay an authorized local shop. Returns are 30 days on unused machines, two-way shipping, 15% restocking on refused shipments. Motobuys has been in business since 1989 and is BBB-accredited. That is a real warranty on a value-tier machine — and still not a Honda dealer network.
Are Chinese dirt bikes any good?
Yes, within their bracket. Engines and frames are generally sound and the machines will do backyard and trail riding for years with maintenance. They are not built to the tolerances, suspension quality or longevity of a Honda or Yamaha, and they are not racing machines.
What is the most reliable Chinese dirt bike?
Broadly, the fuel-injected models in the upper half of any brand's lineup. EFI removes the carburetor, one of the most common nuisance failures, and bikes above about $1,500 get better components throughout.
Do Chinese dirt bikes last?
As long as you maintain them. The early failures we see come from bolts that were never re-torqued and engines run on the original oil, not from design defects.
Is a cheap dirt bike better than a used Honda?
If you want the lowest maintenance and best resale, buy the used Honda. If you want a new machine with a warranty, a known history and orderable parts for a fraction of the price, the budget bike makes sense.
Does a Chinese dirt bike need assembly?
Yes. They ship roughly 85 to 95 percent assembled; bars, front wheel, fenders and fluids are typically left to you. Our warranty requires professional assembly, and poor assembly is the most common cause of early problems.
