What Motorcycles Are Automatic? Auto vs Semi-Auto, Explained
- on September 11, 2026
Three kinds of two‑wheeler have no clutch lever. Scooters run a CVT belt and need no shifting at all. A handful of small motorcycles use a true automatic gearbox. Semi‑automatics still have gears you shift with your left foot — they just delete the lever. Among major brands, Honda’s DCT models are the mainstream automatic option.
That is the whole answer, and almost every buying guide gets one part of it wrong. They treat “no clutch lever” and “no shifting” as the same thing. They are not, and the difference decides whether the machine you order is what you pictured.
Automatic, semi-automatic, and “automatic clutch” are three different labels
Here is what each one actually asks of you.
- •Fully automatic (CVT). A belt runs between two variable pulleys. No gears, no lever, no foot control. Every gas scooter works this way. Twist and go.
- •Fully automatic (geared). A small gearbox shifts itself, usually two speeds. Rare on motorcycle-styled machines, common on kids’ dirt bikes.
- •Dual-clutch (DCT). Two clutches, six or seven real gears, shifted by the bike. This is what Honda sells. It behaves like a car automatic and it costs like one.
- •Semi-automatic. Real gears, a real shift lever under your left foot, and a centrifugal clutch that engages itself. You still shift. You cannot stall it at a stop.
- •Automated clutch. A manual gearbox with the clutch pulled by a motor. Honda calls its version E-Clutch. You shift; you just do not pull anything.
The language on spec sheets is where people get caught. TrailMaster’s own model chart — the one printed inside its dirt bike listings — separates its models into Automatic Clutch, N-1-2-3-4 and Manual Clutch, N-1-2-3-4. Four gears either way. The word “automatic” there describes the clutch, not the transmission. Read the spec table, not the headline.
The automatic motorcycles every buying guide names
Search this question and you will get the same list: Honda’s DCT lineup, the Rebel 1100, the Gold Wing, a few electrics, and a line at the bottom saying scooters are automatic too. The list is correct. It is also priced for a different shopper.
Checked on Honda’s own site the day this was written: the 2026 Rebel 1100 DCT carries a base MSRP of $10,399, and the manual Rebel 1100 alongside it is $9,699. So Honda charges about $700 for the transmission on the same motorcycle. The Rebel 1100T DCT is $11,599 and the DCT SE is $11,199. Honda’s cheapest clutch-free option, the Rebel 300 E-Clutch at $5,349, is not an automatic at all — it is the automated clutch described above, and you still work the shift lever.
What none of those guides cover is the shelf below $5,000, where the answer to “which bikes are automatic” changes completely.
Automatic and semi-automatic machines, priced
Every row below is a machine listed on this site right now, with the transmission taken from that listing’s own spec table rather than from its title. Prices as of September 11, 2026.
| Model | Engine | Transmission (as listed) | Do you shift? | Price |
| RPS 70 Kids Dirt Bike | 70cc | Fully automatic | No | $499 |
| Apollo DB25 | 70cc | Fully automatic | No | $599 |
| Apollo DB38 | 110cc | Fully automatic | No | $699 |
| Tao Pony 50 | 49cc | Fully automatic, scooter | No | $799 |
| RPS Cafe 140 | 140cc | 2-speed automatic | No | $949 |
| Vitacci Milano 150 | 150cc | CVT automatic, scooter | No | $999 |
| TrailMaster JHL PRO SK110E | 107cc | Fully automatic, EFI | No | $999 |
| Ice Bear Maddog Gen V | 150cc | CVT automatic, scooter | No | $1,999 |
| Ice Bear SHDW PMZ200-S | 200cc | CVT automatic, scooter | No | $2,299 |
| Ice Bear Defender PMZ300-T15 | 276cc | CVT automatic, scooter | No | $4,799 |
| TrailMaster TM10 | 107cc | Semi-automatic, 4-speed | Yes — foot only | $649 |
| TrailMaster TM15 | 107cc | Semi-automatic, 4-speed | Yes — foot only | $759 |
| TrailMaster TM23 | 124cc | Semi-automatic, 4-speed | Yes — foot only | $939 |
| Ice Bear PBZ125-2 Champion | 125cc | Semi-automatic, 4-speed | Yes — foot only | $1,249 |
| TrailMaster JHL MK110-ES | 107cc | Semi-automatic, 4-speed, EFI | Yes — foot only | $1,549 |
None of these has a clutch lever. The right-hand column is the one that surprises people.
Two things stand out. First, the automatic answer on two wheels is overwhelmingly a scooter — of the 92 scooters and trikes listed, a CVT belt is the standard fit, and the range runs from a 49cc commuter to a 276cc liquid-cooled machine built for highway speeds. Second, the exception is real: the RPS Cafe 140 is a cafe-racer-styled 140cc with a two-speed automatic and no clutch, which is about as close as this price bracket gets to an automatic motorcycle rather than an automatic scooter.
On the off-road side, of the 96 dirt bikes and pit bikes listed, 16 state a fully automatic transmission in the listing title and 12 state a semi-automatic. The rest are manual, and the manual count climbs sharply above 140cc.
Semi-automatic is not automatic, and this is the call we take
A parent orders a 110cc bike described as semi-automatic, reads “no clutch,” and expects the child to twist the throttle and ride. The bike arrives, the child twists the throttle in neutral, and nothing happens. Nothing is broken. There are four gears down there and someone has to move the lever.
That call comes in most weeks, and the honest answer is that the semi-automatic is usually the better machine for the rider in question. The MK110-ES listing says it plainly: the centrifugal clutch lets a young rider work through the gears without engaging a clutch lever, which is the whole skill of riding a manual minus the part that makes beginners stall. A child who starts on a fully automatic learns throttle and brakes. A child who starts on a semi-automatic learns throttle, brakes, and gears, and steps onto a manual 125 without relearning anything.
So the question to answer before you order is not “which is easier.” It is whether this machine is the last one or the first one.
Which one should you actually buy
Four clean cases, and one honest warning.
- •You want to never think about gears. Buy a scooter. The CVT is the only transmission on this shelf that genuinely requires nothing from you, and 150cc buys real road ability for around a thousand dollars.
- •You want motorcycle looks without shifting. The two-speed automatic 140 is the narrow answer. There is not much else in this price range that is both automatic and shaped like a motorcycle.
- •You are teaching a kid. Fully automatic under about 70cc, semi-automatic from 107cc up. The semi-automatic is the step that pays off later.
- •You want to ride a full-size road bike for years. Learn the clutch. The manual shelf is deeper, cheaper per cc, and the skill transfers to every bike you will ever sit on.
The warning: automatic does not mean maintenance-free. A CVT belt is a wear item and it will need replacing. Engine braking on a CVT is weak, so you use the brakes more coming down a hill. And a centrifugal clutch on a semi-automatic will slip and glaze if it is ridden hard at part throttle, which is the most common way these get cooked in the first season.
What arrives, and what costs extra
Our warehouse is in Garland, Texas, and the machines leave it crated. On most of the small bikes and scooters the owner fits the front wheel, the handlebar, the mirrors and a fender, and the battery arrives dry with the acid packed separately — a dead battery on day one is nearly always an unfilled battery. Assembly service is available if you would rather not, and the phone line is 877-667-6289.
If the machine is one you plan to register, dealer-endorsed MCO and title processing is a separate $39 line item, not part of the sticker. Whether an automatic needs a motorcycle endorsement, and what your state calls a moped, is a state question — ask your own motor vehicle agency rather than taking a number from a blog.
Three clutch-free machines worth a look
Ice Bear PBZ125-2 DLX Champion
125cc · semi-automatic 4-speed · 4.69★ from 29 reviews
$1,249$1,499
ViewStill deciding between a twist-and-go scooter and a geared bike? The scooter and moped range starts at $699, the street bike and enduro range covers the geared side, and what actually makes a bike road legal is a separate question worth reading before you order.
What motorcycles are automatic?
On two wheels the automatics fall into three groups: every gas scooter, which uses a CVT belt; a small number of geared automatics such as two-speed small-displacement bikes; and the large-brand dual-clutch models, of which Honda's DCT range is the main example. Everything else is either manual or semi-automatic.
Do they make automatic motorcycles?
Yes, and more than at any point in the past. Honda builds dual-clutch versions of several models, electric motorcycles have no gearbox at all, and the entire scooter category has been automatic for decades. What is scarce is a full-size automatic road bike under about $9,000.
Are there automatic dirt bikes?
Yes. Of the 96 dirt bikes and pit bikes listed here, 16 state a fully automatic transmission and 12 state a semi-automatic. Automatics cluster under 125cc and are aimed at young or first-time riders; above roughly 140cc the category is almost entirely manual.
Are there automatic sport bikes?
Not in the usual sense. Sport-styled machines under $3,000 are almost all geared and manual, because the gearbox is what makes the styling mean anything. The nearest thing on this shelf is a two-speed automatic in cafe-racer bodywork.
Are scooters automatic?
Yes. A gas scooter uses a continuously variable transmission driving a belt, so there is no clutch lever and no gear selection at all. This is why a scooter is the simplest possible first powered two-wheeler.
What is the cheapest automatic motorcycle?
It depends on what you count. The cheapest fully automatic gas two-wheeler here is a 70cc kids dirt bike at $499. The cheapest automatic machine legal on the road in most states is a 49cc automatic scooter at $799. Road-going automatics from major brands start several thousand dollars higher.
Do automatic motorcycles still need a motorcycle license?
Licensing depends on your state and on how your state classifies the machine, usually by engine size and top speed rather than by transmission. An automatic transmission does not by itself change what license you need. Check with your own state motor vehicle agency before you buy.
