Do You Need a License for a Scooter or Moped With a 49cc Engine?
- on April 03, 2024
Whether you need a license comes down to three things: engine displacement, top speed, and which vehicle class your state puts the machine in. For a sub-50cc moped, most states ask for a regular driver's license rather than a motorcycle endorsement — but registration is a separate question, and the answer changes at the state line.
This is the question we get on the phone more than any other, and the honest answer is that nobody can tell you what applies in your state without knowing your state. What we can do is explain what actually drives the rule, so you know exactly what to look up and what to ask.
The three things that decide the answer
Every state writes its own rules, but almost all of them are built from the same three inputs. Get these three right and you can predict the answer before you call anyone.
| What the state looks at | Why it matters | Typical dividing line |
| Engine displacement | The main sorting mechanism between a moped class and a motorcycle class | 50cc |
| Top speed | Some states classify by speed instead of, or in addition to, displacement | 30 mph |
| Vehicle class | Determines which license, registration and insurance rules attach | Moped vs motorcycle |
Moped or scooter? The difference matters legally
People use the words interchangeably. The law does not. The distinction is what decides which set of rules applies to you.
- •Moped — 50cc or under, top speed typically around 28–30 mph. Originally these had pedals, which is where the name comes from. Modern ones do not.
- •Scooter — anything from 50cc up to 250cc and beyond. Step-through frame like a moped, but once it is over 50cc most states stop treating it like one.
- •Motorcycle — a legal class, not a body style. A 150cc scooter is legally a motorcycle in most states even though nobody would call it one.
So “do I need a license for a scooter” has two different answers depending on which side of 50cc your scooter sits.
Licensing and registration are separate questions
This trips people up constantly. A state can say you do not need a motorcycle endorsement and still require the machine to be registered and titled before it touches a public road. The two requirements are set by different parts of the code and there is no rule saying they move together.
So ask both questions, separately:
- •Do I need a license or endorsement to operate this, and which class?
- •Does the machine itself need to be registered and titled, and does it need a plate?
- •Is liability insurance required, and at what minimum?
How to get the actual answer for your state, in about five minutes
Do not rely on a blog for this — including ours. State codes change and a page written two years ago can be confidently wrong. Here is the reliable path:
•Search for your state's DMV site plus the word moped. Use the
.govresult, not an aggregator. - •Look for the vehicle class definition first. Find where your displacement and top speed land you.
- •Then read the license, registration and insurance requirements attached to that class.
- •If your machine is right at 49 or 50cc, confirm whether the state measures at, above or below the threshold. That one word changes the answer.
What we sell in the sub-50cc class
If you have worked out that a moped-class machine is what you want, these are three we keep in stock. All three are 49–50cc, fully automatic and electric start, which is the configuration most first-time riders should be looking at.
Browse the full range of scooters, mopeds and trikes, or call 877-667-6289 if you want to talk it through. The phone goes to our Garland, Texas warehouse — the same building the machines ship from.
Every 49cc and 50cc machine we carry is on one page: 50cc scooters and mopeds.
Do you need a license to drive a moped under 50cc?
In most states yes, but usually only a regular driver's license rather than a motorcycle endorsement. A handful of states require a moped-specific permit, and a few require nothing beyond a photo ID. The engine being under 50cc is what keeps it out of the motorcycle category in most states, not what exempts it from licensing.
What cc is street legal without a license?
There is no national cc threshold that removes the license requirement. The common dividing line is 50cc and 30 mph: below both, most states treat the machine as a moped with lighter requirements; above either, most states treat it as a motorcycle. But the exact rule is set by your state, and a few require a license at any displacement.
Does a 49cc moped need to be registered?
Usually yes. Registration and licensing are separate requirements and states often handle them differently. It is common to need registration and a title even where no motorcycle endorsement is required. Check with your DMV before you ride on a public road.
Do you need a license to drive a scooter?
It depends on displacement. A scooter over 50cc is treated as a motorcycle in most states, which means a motorcycle license or endorsement. Under 50cc it usually falls into the moped class with lighter requirements.
Can you drive a moped with a regular license?
In many states yes. A standard driver's license is the most common requirement for a sub-50cc moped. That is the single most likely answer, but it is not universal, so confirm it for your state.
Do you need insurance for a 49cc moped?
Some states require it, some do not, and it often tracks with whether registration is required. Even where it is optional, liability coverage is worth having on a road-legal machine.
Still deciding between a 50cc and something larger? Our moped vs scooter comparison covers what you gain and give up at each size. Or see everything in scooters and mopeds.
