How Tall Is a 125cc Dirt Bike? Seat Heights and Who Fits (2026)
- on October 16, 2026
A 125cc dirt bike is not one size. The 125s in our table sit between 29 and 34 inches at the seat: the 14-inch-wheel youth bikes run lowest, the 17-inch-wheel bikes run highest. Tall teens and adults belong on the 33- to 34-inch bikes. Match your inseam to the listed seat height, not to the cc badge.
Most guides on this question talk about 125s in the abstract. Below are the numbers copied from real listings, sorted by seat height, plus how to turn them into a decision. If you want the engine-size question first, start with our guide to 125cc dirt bikes for beginners; this page is only about fit.
How tall is a 125cc dirt bike?
Taller than the youth label suggests, and less consistent than the cc number implies. Among the 125-class bikes we list that state a seat height, the range runs from 29 to 34 inches. That is a five-inch spread inside one engine size, which is the whole difference between a ten-year-old and a six-foot adult.
Front wheel size is a clue, not a rule. The 17-inch bikes in the table all sit at 32.7 inches or higher. But the Apollo DB-X15 and DB-X16 run 14-inch front tires and still sit at 33 inches, so you cannot read height off the wheel. Read the listing.
125cc dirt bike seat heights and prices, October 16, 2026
Every bike below is active and in stock today, pulled from the live catalog. Seat heights, tire sizes and gearboxes come from each listing title. Bikes whose titles do not state a seat height are left out rather than guessed.
| Model | Engine | Gearbox / start | Front tire | Seat height | Price |
| Apollo Ultramax DB-X6 | 125cc | Fully automatic, kick | 14 in | 29 in | $779 |
| TrailMaster TM23 | 124cc | Semi-auto, electric | 14 in | 29.3 in | $939 |
| Apollo DB-X5 RFZ | 125cc | 4-speed manual, kick | 14 in | 30 in | $779 |
| TrailMaster TM24 | 124cc | Semi-auto, electric | 17 in | 32.7 in | $979 |
| Apollo DB-X16 | 125cc | Fully automatic, kick | 14 in | 33 in | $799 |
| Apollo DB-X15 | 125cc | 4-speed manual, kick | 14 in | 33 in | $799 |
| Ice Bear Whip 125 PAD125-3 | 125cc | 4-speed manual, kick | 17 in | 33 in | $1,199 |
| TrailMaster TM29 | 124cc | Manual, electric | 17 in | 33.5 in | $1,089 |
| Apollo DB-X18 | 125cc | 4-speed manual | 17 in | 34 in | $899 |
| Apollo Thunder T20 | 125cc | 4-speed manual, kick | 17 in | 34 in | $899 |
Prices and availability as of October 16, 2026. Spec lines are copied from each product page title; open the page for the full specification. Seat height is quoted with no rider aboard.
Browse the full group on the 125cc dirt bikes collection or the wider dirt bike and pit bike range.
Best 125cc dirt bikes for tall riders
If the rider is tall, skip everything under 32 inches. The three that make sense are the Apollo Thunder T20 and Apollo DB-X18 at 34 inches, and the TrailMaster TM29 at 33.5 inches with electric start. All three are manuals, which is the honest trade-off: height comes with a clutch.
A call we get often goes like this: a tall teen or a grown adult wants a 125 because they heard it is easy, and the first bike they look at is a 29-inch youth model. It will be easy to start and miserable to sit on, knees up near the bars. Move to the 17-inch bikes. And if the rider is a large adult, be straight with yourself: a 125 may be the wrong class. The next step up is covered in our 150cc dirt bike guide.
Best 125cc dirt bikes for shorter riders
Go the other way for a newer or smaller rider. The Apollo Ultramax DB-X6 (29 inches, fully automatic) and TrailMaster TM23 (29.3 inches, semi-automatic with electric start) are the lowest in the table. The DB-X5 adds a real clutch at 30 inches for a rider who already has some seat time. Gearbox choice matters about as much as height for a first bike, and we walk through it in the beginner guide.
How to check that a 125 will fit before you buy
Use the flat-foot test. In the boots they will actually ride in, can the rider get the balls of both feet on the ground while sitting? If not, the bike is too tall, whatever the engine size. A rider who cannot hold the bike up at a stop will drop it, and a dropped bike ends the day.
Remember that listed seat height is measured unloaded. Once someone sits, the suspension sags a little, so a bike listed at 34 inches will feel a touch lower in use. That helps a tall rider and gives a short rider no help at all. Measure the inseam, compare it with the table, and when two bikes both fit, take the one with the gearbox the rider can manage.
The 125 label is also a class, not a measurement. The TrailMaster TM23, TM24 and TM29 are 124cc engines and sell as 125s. Nobody is hiding anything; you will not feel the difference on a trail.
What to do when the bike arrives
A 125 dirt bike is not a toy and does not arrive ready to ride. Many of our listings offer an assembly option on the product page, so check that before you order if you would rather not build it. Either way, run the same short checklist before the first ride.
- •Oil level and the first oil change. Change the factory oil early, after the first few hours, and follow the manual for the interval.
- •Chain slack and sprocket bolts. Set the slack to the manual’s spec, neither tight nor floppy.
- •Axle nuts, handlebar clamps and fork bolts. Re-torque them, then check again after the first ride.
- •Tire pressure. Set it for the trail, not for the crate.
Our warehouse is in Garland, Texas. If you want a person to confirm a seat height, a gearbox or an assembly option before you order, call 877-667-6289.
Three 125cc bikes to start with
One for tall riders, one for the middle, one for a smaller rider who wants electric start.
TrailMaster TM23 Youth Dirt Bike
124cc · semi-automatic · electric start · 29.3 in seat
$939$1,149
ViewFrequently asked questions
Among the 125cc bikes in our table, listed seat heights run from 29 to 34 inches. The 14-inch-wheel youth models sit lowest and the 17-inch-wheel bikes sit highest, though two 14-inch bikes here still sit at 33 inches.
How tall is a 125cc dirt bike for adult?
Adults should look at the 17-inch-wheel bikes. The Apollo Thunder T20 and DB-X18 list a 34-inch seat height and the TrailMaster TM29 lists 33.5 inches. All three are manuals.
How big is a 125cc dirt bike?
Size varies more than the engine badge suggests. The listed seat heights span 29 to 34 inches, and front tires are 14 or 17 inches. Compare the rider’s inseam to the seat height on the specific listing.
What are the best 125cc bikes for tall riders?
For height, the Apollo Thunder T20 (34 inches), Apollo DB-X18 (34 inches) and TrailMaster TM29 (33.5 inches) are the tallest 125s in our table. A very large adult may be better served by a 140–150cc bike.
Is a 125cc dirt bike good for beginners?
Yes for most teens and smaller adults, provided the seat height fits. Fully automatic and semi-automatic 125s such as the Apollo DB-X6 and TrailMaster TM23 are the gentlest starting points.
Do 125cc dirt bikes come assembled?
No. Plan on some assembly and a pre-ride check. Many of our listings offer an assembly option on the product page, so look for it before you order.
Not sure which seat height fits? Call 877-667-6289 or browse the 125cc dirt bike collection. For prices across all engine sizes, see our dirt bike price guide.
