150cc Dirt Bike Guide: Who It Fits, Real Specs and Prices (2026)
- on October 05, 2026
A 150cc dirt bike is the step between a 125cc starter and a 250cc full-size. It has the pull for an adult beginner on trails and sits low enough for a taller teen. Ignore the badge, though: the 150s we list run 140 to 156cc, so judge them by gearbox, seat height and start type.
Many guides on this topic walk through Honda and KTM race bikes. If you are shopping the budget end, that tells you very little. Below is what a 150-class bike actually is, who it fits, and what the ones on our shelf look like today. You can browse the whole group on the 140cc and 150cc dirt bike collection.
Is a 150cc dirt bike good for beginners?
Yes, with one condition: the rider has to be willing to learn a clutch. That condition matters more than the cc number. Every in-stock 140–156cc bike in the table below is a manual with a foot shifter, so you will be pulling a lever and rocking a shift pedal from the first minute.
What a 150 gives you is a bike that climbs a trail without feeling frantic. It pulls hard enough to carry an adult up a hill, but a stall or a mistake is still recoverable. A 250 is a different machine and we cover it in our 250cc beginner guide. If you want no clutch at all, go down a size instead of up, and read are 125cc dirt bikes good for beginners.
How tall is a 150cc dirt bike?
Taller than the number suggests. Among the bikes below, the listings that state a seat height run from 32.2 to 34.5 inches, and front tires are either 17 or 19 inches. The 17-inch bikes feel lower and lighter. The 19-inch bikes roll over ruts and roots with less fuss but ask more of a short rider.
Age and size charts for dirt bikes are a convention, not a rule, so ignore any chart that gives a single age. Do this instead: stand next to the bike, imagine sitting on it, and ask whether the balls of both feet would reach the ground. If not, you are looking at the wrong bike, or the right bike a year too early. Seat height is quoted with no rider aboard, and the suspension sags a little once you sit.
150cc dirt bike prices and specs, October 5, 2026
Here is every 140–156cc dirt bike we list that is in stock today, pulled from the live catalog and sorted by price. Seat heights come from each listing title.
| Model | Engine | Gearbox / start | Front tire | Seat height | Price | Rating (reviews) |
| Apollo Thunder 140 | 140cc | 4-speed manual, kick | 17 in | 33 in | $999 | 5.0 (2) |
| Apollo Thunder 150 DLX | 140cc | 4-speed manual, kick | 19 in | 34.5 in | $1,099 | 4.67 (3) |
| RPS Viper 150 | 149cc | 5-speed manual, kick | 19 in | not listed | $1,129 | 4.67 (3) |
| RPS Viper-E | 149cc | 5-speed manual, electric | 19 in | 32.2 in | $1,179 | 5.0 (2) |
| TrailMaster LK140 | 140cc | Manual, electric | 17 in | 32.9 in | $1,199 | 5.0 (1) |
| TrailMaster C50 | 145cc | Manual, electric | 17 in | 33.5 in | $1,199 | 5.0 (2) |
| TrailMaster C60 | 156cc | 4-speed manual | 19 in | 34 in | $1,599 | — |
| TrailMaster JHL SX150 | 140cc | Manual, electric | 19 in | 32.7 in | $1,829 | — |
Prices and availability as of October 5, 2026. Spec lines are copied from each product page title; open the page for the full specification.
The cheapest bike in the table is $999 and the most expensive is $1,829. The middle of the range clusters around $1,099 to $1,199. For how that sits against smaller and larger engines, see our dirt bike price guide by engine size.
Two things are worth paying for. First, electric start: the Viper-E, LK140, C50 and SX150 list it in the title. On a kick-start bike a stall halfway up a hill means kicking uphill with the bike leaning on you, and a beginner will stall. Second, the fork. The LK140 lists inverted forks at $1,199, which is the cheapest way into that hardware in this table.
Why does a 150 say 140 on the listing?
Because “150” is a class, not a measurement. The Apollo Thunder 150 DLX is a 140cc engine. The TrailMaster JHL SX150 is a 140cc. The RPS Viper 150 is 149cc, the TrailMaster C50 is 145cc and the C60 is 156cc. Every one of them sells as a 150.
Nobody is hiding anything, and you will not feel the difference between 140 and 149cc on a trail. But if a shop quotes you a 150 and the title says 140, both are right. What you should compare instead is the frame, the tire size, the gear count and whether it starts with a button.
150cc vs 125cc vs 250cc: which one?
Pick the 125 if the rider is smaller, new to everything, or you want an automatic clutch option. Pick the 150 if the rider is tall enough, has some seat time, or is an adult beginner who will outgrow a 125 within a season. Pick the 250 only if you already ride, or if you are heavy and want power in reserve. A common mistake is buying the biggest engine the budget allows, finding it intimidating, and riding less.
There is also a middle case, the 110cc to 150cc jump. It is real, but it is mostly about the gearbox and frame, not the 40cc. A 110cc youth bike with a semi-automatic and a 150cc manual are different bikes, not the same bike with more power.
What to check when the bike arrives
A dirt bike this size is not a toy and it does not arrive ready to ride. Plan for it. Many of our listings offer an assembly option on the product page, so check that before you order if you would rather not build it. Either way, do the same short checklist before the first ride.
- •Oil level and the first oil change. Change the factory oil early, after the first few hours of riding, and follow the manual for the exact interval.
- •Chain slack and sprocket bolts. Set the slack to the manual’s spec, neither tight nor floppy.
- •Axle nuts, handlebar clamps and every fork bolt. Re-torque them, then check again after the first ride.
- •Tire pressure. Set it for the trail, not for the crate.
Our warehouse is in Garland, Texas. If you want a person to confirm a seat height, a gearbox or an assembly option before you order, call 877-667-6289.
Three 150-class bikes to start with
If you do not want to compare all eight, these three cover the useful range: the cheapest in the table, the best value with electric start and inverted forks, and the premium option.
How much is a 150cc dirt bike?
Today the 140–156cc dirt bikes in our table run from $999 to $1,829, depending on the frame, brakes, forks and whether it has electric start. Prices change, so the table above carries the as-of date.
The listings that state a seat height run from 32.2 to 34.5 inches with a 17-inch or 19-inch front tire. That is a full-size bike, so check the number against the rider before you buy.
Is there a 150cc 2 stroke dirt bike?
None of the 140–156cc bikes in our table is listed as a two-stroke. Most two-stroke 150s are competition bikes from the large Japanese and European brands, priced accordingly. Check the specification on the product page for engine type.
Is there an automatic 150cc dirt bike?
Right now the in-stock bikes in our table are all manual. The fully automatic bikes in the catalog are smaller, such as the 125cc Apollo DB-X16, so the no-clutch route starts with a smaller engine.
What is the difference between a 110cc and 150cc dirt bike?
Mostly frame and gearbox. The 110cc bikes are youth-sized, often semi-automatic, with a small front wheel. The 150-class bikes are adult frames with a manual gearbox and a 17 or 19-inch front tire.
What is the cheapest 150cc dirt bike?
As of October 5, 2026, the lowest price in our 140–156cc group is the Apollo Thunder 140 at $999. Browse the whole range on the 140cc and 150cc collection.
Not sure which size fits? Browse all dirt bikes or call 877-667-6289 and we will help you match the bike to the rider.
