How Much Does a Go-Kart Cost? Real Prices by Size and Engine
- on September 18, 2026
A new gas go-kart costs $1,129 to $6,999 at Motobuys as of 18 September 2026. Kids’ karts run $1,129 to $1,899, youth buggies with a full roll cage $1,249 to $2,399, and full-size adult carts start at $2,599. Electric kids karts begin at $899. Nothing real exists under $500.
Search this question and half the answers are about renting a lap at an indoor track. Most of the rest price racing chassis — sprint karts, shifter karts, Cadet classes. Almost none of them tell you what a gas off-road kart you can put in a truck and drive on your own land actually costs.
Here is that number, taken off our own go-kart listings this morning.
Go-kart prices by type, 18 September 2026
| Type of kart | Engine | Models listed | Price range |
| Electric kids kart | 500W to 48V battery | 2 | $899 – $1,599 |
| Gas kids kart | 110cc – 163cc | 6 | $1,129 – $1,899 |
| Youth buggy, roll cage | 200cc – 212cc | 9 | $1,249 – $2,399 |
| Full-size adult cart | 168.9cc – 208cc | 18 | $2,599 – $4,299 |
| Water-cooled adult buggy | 275.6cc – 300cc | 6 | $4,199 – $6,999 |
| Electric teen and adult | 48V – 60V lithium | 2 | $2,659 – $3,999 |
Current prices for the 43 go-karts listed and available to order on motobuys.com as of 18 September 2026. Displacement read from each listing’s own spec table, not from the model name. Prices change.
Why there is nothing at $100 or $500
People search for go-karts under $500 constantly, and under $200, and under $100. The honest answer is that those price points buy a pedal kart, a plastic ride-on toy, or a used frame with no engine. A $100 go-kart is a toy with a seat.
The floor for a machine with a real four-stroke engine, a welded roll cage, hydraulic disc brakes and a harness is a little over $1,100. Ours starts at $1,129 for the TrailMaster Mini XRS+, a 163cc pull-start kids kart with lap belts and no reverse. Below that we list one electric kart at $899, a single-seat 500W machine its own listing puts at ages 6 to 10.
If you see a gas kart advertised at $400, look at what is missing: usually the roll cage, usually the brakes, sometimes the engine. That is the part the listing does not say out loud.
The number in the model name is not the engine size
This trips up almost everyone who cross-shops on displacement. In this segment the model number is marketing, not a spec.
- •The TrailMaster Cheetah 200 is a 169cc engine.
- •The Vitacci Jag 200 EFI is 168.9cc.
- •The TrailMaster Cheetah 8 is 208cc — bigger than most of the “200” carts.
- •The TrailMaster KX300, Cheetah 300PRO and Eagle 300XRSE are all 275.6cc.
- •The RPS GKR Cobra is the rare honest one: it is called a 177cc, and it is a 177.3cc.
So if you are comparing two carts and one says 200 and one says 177, you may be looking at a 169cc and a 177.3cc — and the “smaller” one has the bigger engine. Open the spec table on each listing and read the displacement line. Every one of the figures above came off ours.
Price does not follow displacement either
The TrailMaster Apache 7 is a 212cc youth kart at $1,399. The Cheetah 200 is a 169cc adult cart at $2,999. The cheaper kart has the bigger engine, and it is not a mistake.
What the extra $1,600 buys is everything around the engine: a longer wheelbase, coil-over shocks at all four corners, wider tires, a bigger fuel tank, hydraulic discs front and rear, a CVT with reverse instead of a torque converter, and a seat and pedal box built for an adult rather than adjusted down for a nine-year-old. Frame and suspension move the price in this category. Displacement barely does.
What the published price guides leave out
The best-ranking retail answer to this question is GoKarts USA’s guide from August 2026. It is a careful piece and it does something odd: it gives a number for every category except the one most people are buying. Pedal karts, $100 to a few hundred. Electric hobby karts, $300 to $1,500. Entry racing karts, $1,500 to $2,500 used and $3,000 to $6,000 new. Advanced racing, $5,000 to $15,000 and up. Recreational gas karts — the ones families actually want — are described as costing “in the low thousands.”
That is the whole segment, priced with a shrug. Our own shelf says it more precisely: the recreational gas band runs $1,129 to $4,299, and above that you are into 275cc water-cooled machines that overlap with side-by-sides.
Which brings up the second thing the guides miss. Several of the carts in our $2,599 to $4,149 range are listed by the manufacturer as “Off Road UTV / Go Kart” — the Cheetah 8, the Cheetah 200X, the Cheetah 200EX. At this price the two categories are the same machine with two names on it. If you are shopping that band, read our side-by-side price guide alongside this one, because you are choosing between overlapping shelves, not between two different vehicles.
What you pay on top of the sticker
Three things, and only one of them is obvious.
- •Assembly. A kart arrives crated. On a kids kart that usually means fitting wheels, the seat, the steering wheel and the roll bar, checking the chain and filling fluids. We list several models in both a crated and a 95% pre-assembled version, and the gap between the two is $200 or less — on the Mini XRX/R+ it is $1,549 against $1,749. We also do assembly here in Garland, Texas if you would rather not.
- •Dealer-endorsed MCO and title processing, where your state requires paperwork for an off-road vehicle. It is a separate line item at checkout, not part of the sticker price.
- •A helmet. GoKarts USA puts helmets at $80 to $400 and gloves at $20 to $80 in its first-year budget, which matches what we see. Buy the one that fits, not the expensive one — a loose $300 helmet protects a child worse than a snug $90 one.
What you will not pay for, on most of these: a battery that works out of the crate. Gas karts with electric start arrive with the battery dry or disconnected, and “it will not start” is the number one call we get in the first week. Fill it, charge it, then try.
Which price band fits you
Three questions get you there faster than browsing.
Who is driving, and how big are they? Under about ten years old and you want the kids band, $1,129 to $1,899, where the seat adjusts inward and most listings include a speed governor. Ten and up, or a mixed-age household, and the youth buggies at $1,249 to $2,399 are the right shelf — they are the ones parents keep as the child grows. For a full-grown adult, $2,599 is the real starting point; below it you will be folded into the seat. Our kid fit guide has the measurement that actually matters.
How rough is the ground? A flat yard or a gravel drive does not need suspension travel, and you can stay in the lower bands. Real trail riding, ruts and jumps means coil-overs at all four corners and a full cage, which is the $2,599-and-up band.
How many seats? Two is standard. Four costs real money — the only four-seaters we list that say so on the box are the Blazer 4-200EX at $4,299 and the fully assembled CRT Moto DF200GHA at $3,999. If the whole family rides at once, budget from $3,999 and stop looking at the $2,000 shelf.
Three karts, three price points
163cc kids kart · bench seat, pull start, roll cage · rated 4.86 out of 5 from 7 reviews
$1,129$1,349
169cc full-size adult cart · welded roll cage, high-back seats · rated 5.0 out of 5 from 6 reviews
$2,999$3,249
ViewEverything we list sits in go-karts, split into karts for kids and karts for adults if you already know which end of the range you are in.
The full-size adult machines are grouped under go-karts over 200cc.
How much is a go-kart for adults?
A full-size adult go-kart starts at $2,599 and runs to $6,999 for a 275.6cc water-cooled buggy. The $2,599 to $4,299 band covers 168.9cc to 208cc two- and four-seat carts and is where most adult buyers land. Below $2,599 you are looking at youth-sized machines that an adult will not fit comfortably.
How much is a go-kart for a kid?
$1,129 to $1,899 for a gas kids kart with a 110cc to 163cc engine, a roll cage and belts. Electric single-seat karts for younger children start at $899. Youth buggies sized to grow with a rider aged ten and up run $1,249 to $2,399.
What is the cheapest go-kart?
On our site, $899 for an electric single-seat kids kart and $1,129 for the cheapest gas kart, a 163cc pull-start machine with a roll cage and lap belts. Anything advertised far below that is a pedal kart, a ride-on toy, or a frame missing its engine or brakes.
How much is an electric go-kart?
$899 to $1,599 for kids electric karts, and $2,659 to $3,999 for 48V to 60V lithium machines built for teenagers and adults. Electric karts cost more per unit of size than gas at the small end and have far less to maintain — no oil, no carburetor, no fuel.
Are go-karts street legal?
Almost never. An off-road go-kart is not built or certified as a road vehicle, and adding lights and mirrors does not change its classification. Several of our listings say “OFF ROAD ONLY, NOT STREET LEGAL” in the product title. Registration rules differ by state, so check with your own state motor vehicle agency rather than any retailer — we cover what actually decides it in our guide to UTV and go-kart road legality.
Is a go-kart an ATV?
No. An ATV is a straddle-seat machine with handlebars that you ride. A go-kart has a bucket seat, a steering wheel and pedals, and you sit in it. They are separate federal categories with separate rules, which is why youth ATV age guidance does not apply to karts.
How much does a new go-kart cost compared with used?
New karts in the bands above carry a manufacturer warranty on the engine and major components. A used kart at half the price with no service history is often a chain, a carburetor and a set of tires away from the same total. Ask any private seller for the original invoice.
Not sure which band you need? Call us at 877-667-6289. We are in Garland, Texas, we assemble these ourselves, and we will tell you if the kart you are looking at is too small for the rider — before you buy it.
