What Size Go-Kart for a Kid? Age and Fit Guide (Ages 5–14)
- on August 25, 2026
For most kids the right go-kart is set by leg reach, not by age. Ages 5 to 10 fit a mini kart with 28–32 inches of pedal-to-seat-back adjustment and a working throttle limiter. Ages 8 to 14 need a mid-size chassis at 31–40 inches. Measure the child first, then compare engines.
Every parent who calls us about a kids go-kart asks the same first question, and it is the wrong one. They ask how many cc. Engine size decides how fast the kart can go. It does not decide whether your child can drive it. Fit does. A kid who has to slide down the seat to reach the brake cannot stop the kart, and no amount of horsepower makes up for that.
Here is the number that matters and that almost nobody publishes: pedal-to-seat-back distance. TrailMaster prints it in the spec sheet for every model. It is the range the driver’s seat slides through, measured from the seat back to the pedal face. Match it to your child and the rest of the decision gets easy.
How to measure your kid in 60 seconds
Sit your child in a hard kitchen chair with their back flat against the chair back. Run a tape from the chair back to the bottom of the heel, leg almost straight — a slight bend at the knee, not locked. That number is what you compare against the seat range in the table below.
- •Under 28 inches — too small for anything in this class. Give it a year.
- •28 to 32 inches — mini kart. Roughly ages 5 to 10.
- •31 to 36 inches — the overlap zone: a mini at its longest setting, or a mid-size at its shortest.
- •36 inches and up — mid-size kart. Roughly ages 10 to 14.
Karts arrive with the seat at its rearmost position, so the first thing to do after assembly is slide it forward. On the mini models the pedals adjust as well, which buys another couple of inches at the small end.
Kids and youth go-karts at MotoBuys: age, seat reach and price
Every row below is a model that is active and buyable on our site right now. The age column comes from the manufacturer’s own listing for that specific model, not from a generic chart, and the prices are what you would pay today.
| Model | Power | Seats | Age (per maker) | Pedal to seat back | Price |
| TrailMaster i3 Electric | 500W electric | 1 | 6–10 | 28″–32″ | $899 |
| Eagle Mini XRS+ | 163cc gas | 2 | 5–11 | — | $1,129 |
| Eagle Mini XRX+ | 212cc gas | 2 | 5–10 | — | $1,249 |
| Eagle Mini XRX/R+ | 212cc gas | 2 | up to 10 | 30″–35″ | $1,549 |
| Cheetah i6 Electric | 48V electric | 2 | 6–12 | 28″–32″ | $1,599 |
| Eagle Mid XRX | 212cc gas | 2 | 8–14 | 31.5″–40.5″ | $1,699 |
| Cheetah 6 | 163cc gas | 1 | 6–12 | 28″–32″ | $1,899 |
| Eagle Mid XRX/R | 212cc gas | 2 | 10–13 | 31.5″–40.5″ | $2,299 |
| Blazer 200R | 200cc gas | 2 | 10 and up | 34″–39″ | $2,399 |
| Cheetah 8 | 208cc gas | 2 | 10 and up | 32″–38″ | $2,649 |
Read from the MotoBuys catalog on 25 August 2026; prices and availability change. Where a listing publishes no seat-adjustment figure the cell is left blank rather than estimated. The TrailMaster Cheetah 3 80cc is not listed because it is out of stock today.
What size go-kart for a 10-year-old?
Ten is where the answer genuinely splits, which is why it is the question we get most. A small ten-year-old is still inside the mini range and will be comfortable on an Eagle Mini XRX/R+ for another season. A tall ten-year-old is already at 34 or 35 inches and will be cramped by spring.
If your measurement lands within two inches of the top of a mini kart’s range, buy the mid-size instead. That is the one place where sizing up is the right call, because a mid-size chassis has a throttle limiter you can set low while your child grows into it. What does not work is putting a seven-year-old on a mid-size kart on the theory that it will last longer. It will not fit for three years, and a kart that does not fit is a kart nobody rides.
Ages 5 to 8: start slow and keep the kill switch
At this age the useful features are the boring ones. A throttle limiter is a screw on the gas pedal that caps how far it travels, so you set the top speed rather than the child. A remote kill switch is a fob that cuts the engine from wherever you are standing. The i3 tops out at 10 mph across three speed settings, the lowest around 5 mph — slow enough that a five-year-old learns steering before they learn speed.
There is a second reason we point first-time buyers at electric. A young child physically cannot pull-start a small gas engine. Buy a pull-start kart for a six-year-old and you are the one starting it, every time, all afternoon. Check the start type on the listing before you order.
Ages 10 to 14: mid-size, and the reverse gear question
Mid-size karts here run 200cc to 212cc with a torque converter, and they will move if you let them — which is why the limiter matters more at this age, not less. The bigger practical decision is reverse. Models with an R in the name have it: Mid XRX/R, Mini XRX/R+, Blazer 200R. On open land you can live without it. On a wooded trail or a fenced yard, a kid who noses into a corner without reverse has to climb out and drag a few hundred pounds of steel backward, and they will do that exactly once before the kart stops leaving the garage.
You can see the full range on Go Karts for Kids and Go Karts for Youth, or the whole catalog including adult models on Go Karts.
Three karts we would start with
One per stage. All three are active and buyable as of today.
TrailMaster i3 Electric Kids Go-Kart
500W electric · single seat · ages 6–10 · 3 speed settings, reverse
$899$1,099
View kart
TrailMaster Eagle Mini XRX/R+
212cc · 2 seats · up to age 10 · 4.77★ from 13 reviews
$1,549$1,849
View kart
TrailMaster Eagle Mid XRX
212cc · 2 seats · ages 8–14 · 4.45★ from 11 reviews
$1,699$1,999
View kartWhat people search for, answered
What size go-kart is right for a 10-year-old?
Ten is the crossover age. A child at the small end of ten still fits a mini kart such as the Eagle Mini XRX/R+, which adjusts from 30 to 35 inches pedal-to-seat-back. A taller ten-year-old has already outgrown it and belongs on a mid-size kart like the Eagle Mid XRX at 31.5 to 40.5 inches. Measure the seated leg reach rather than going by birthdays.
How much is a go-kart for a kid?
At MotoBuys on 25 August 2026, kids and youth go-karts run from $899 for the single-seat TrailMaster i3 electric to $2,649 for the two-seat Cheetah 8. The heart of the range — a two-seat mini kart with a roll cage, harness and throttle limiter — sits between $1,129 and $1,549.
What age can a kid start driving a go-kart?
Manufacturer guidance on the karts we stock starts at 5 or 6 years old, on a low-power model with an adult holding the remote kill switch. Nothing in this range is designed for a child under 5. That age is the manufacturer’s recommendation, not a legal rating, and you are still the one deciding whether your child is ready.
Is an electric or gas go-kart better for a young child?
Electric, for a first kart, if the budget allows. A six-year-old cannot pull-start a small gas engine, and the i3 tops out at 10 mph with three speed settings, the lowest near 5 mph — the right speed for learning throttle control. Gas wins on run time: you refuel in a minute, while the Cheetah i6 is rated at about 30 miles per charge.
Can two kids ride in one go-kart?
Yes. Most of the karts in the table above are two-seaters with a bench or twin sports seats and a belt for each rider. Only the i3 and the Cheetah 6 are single-seat. If two kids will ride together, buy the two-seat version from the start — there is no retrofit.
Do MotoBuys go-karts come assembled?
They ship crated and largely built, with wheels, seats, roll cage and steering wheel as the usual owner tasks — a two-person job that takes an afternoon. Several models, including the Cheetah 6, Mid XRX/R and Blazer 200R, are also stocked in a 95% pre-assembled version. Call 877-667-6289 and ask which one is in the Garland, Texas warehouse before you order.
Not sure which size your child sits between? Call 877-667-6289 with the leg measurement from the test above. We ship these out of our Garland, Texas warehouse, and we will tell you straight if the kart you are looking at is a year too early. If you would rather start from a shortlist of models than from a size, read The 5 Best Kids Go Karts.
