The Maddog Gen V 150: Who Should Buy It, and Who Shouldn't
- on September 17, 2026
The Ice Bear Maddog Gen V 150 is the scooter our customers choose more often than any other. It also costs more than any other 150cc scooter on the shelf. Those two facts sitting next to each other tell you something honest about what people are really buying — and about who should walk straight past it.
Nobody cross-shops their way to a Maddog. They see one, and then they want that one. So the useful question is not whether it is a good scooter. It is whether the job you have in mind is the job it does.
What a Maddog actually is
It is a Ruckus tribute: exposed frame, nothing to hide behind, a fat rear tire on black alloy rims front and rear, a single round LED headlight and a cafe-racer handlebar. The Gen V adds an extended frame, a long rear fender and a custom exhaust. The seat sits at 23.2 inches, which is low.
Underneath the look it is conventional and well understood: a 150cc GY6 clone, carbureted, CVT automatic, belt drive, disc front and drum rear, and a listed 246 lb load capacity.
Who should buy it
Three riders, and they are not the same person:
- •The second machine. One of our reviewers put it better than we could: he rides it “on nice days for short hops I do not want to bring my motorcycle out for.” That is the honest use case: the machine you take out instead of waking the big one.
- •The tinkerer. The GY6 is one of the most modified small engines on earth, and the Maddog is a bare frame around one. Another review calls it “a great GY6 bike right out the gate. If you are planning on upgrading, it only gets better.”
- •The person who wants to be looked at. A real reason, and we are not going to pretend otherwise. One buyer wrote that he was “one of the first in my area and it’s turning heads.” If that is the point, nothing else here competes.
The Gen V 150 carries a 5.0 rating from 9 reviews. Nine is a small sample and we would rather you know that than be impressed by the number.
Who should not buy it
You need to carry things
The listing’s feature list is a digital speedometer, a horn, an odometer and bar-end mirrors. No trunk, no advertised storage. That is not an oversight; the bare frame is the design. If your commute involves a laptop bag or a grocery run, you will be wearing it.
You are buying transportation, not a shape you like
If the job is getting to work and back, the Vitacci Tank Pro 200 EFI at $1,249 is the better machine on paper, and $750 cheaper. Fuel injection instead of a carburetor, disc brakes at both ends instead of a rear drum, a locking trunk plus under-seat storage, and a 331 lb capacity against the Maddog’s 246. It is not as cool. It was not trying to be.
You are tall, or you want to ride two-up
A 23.2-inch seat puts most adults in a knees-up position. One tall reviewer says it is “comfortable for tall people when you add peg extensions,” which is a compliment with an instruction buried in it. And at a stated 246 lb capacity, a second adult plus a rider is arithmetic that usually does not work.
You want it ready to ride the moment the crate opens
Per the listing, you fit the front wheel, both fenders, the handlebars, the mirrors, the speedometer and the battery. An evening with basic tools, not a weekend — but not nothing. And a carburetor on a machine that sits for a month at a time will eventually ask for attention a fuel-injected scooter would not.
Same money, opposite machine
The only other scooter at $1,999 in our catalog is the Amigo Avenza 200-A, and putting them side by side is the fastest way to see what your money is choosing.
| Maddog Gen V 150 | Amigo Avenza 200-A | |
| Price | $1,999 (was $2,279) | $1,999 (was $2,299) |
| Engine | 150cc, carbureted | 200cc (listed est.), 4-stroke |
| Brakes | Disc front / drum rear | ABS disc front / drum rear |
| Wheels | 14 in, front and rear | 10 in |
| Seat height | 23.2 in | 31 in (approx.) |
| Load capacity | 246 lb | 330 lb |
| Storage | None listed | Trunk, under-seat, windshield |
| The idea | Be looked at | Be useful |
Neither column is wrong. If you read that table and drifted right, buy the Avenza and enjoy the trunk. If you read it and still wanted the left-hand column, you have your answer and can stop shopping.
The $400 question
There is a second Maddog Gen V, and it is the one people overlook. The Gen V 49.5cc is $1,599. Same body, same 23.2-inch seat, same 14-inch rims, same 82.7-inch frame, a 242 lb capacity against 246. The difference between the two machines is the engine and four hundred dollars.
So the question is not which looks better, because from ten feet away nobody can tell. It is whether your riding is neighborhood-scale or road-scale. Settle one thing first: displacement is what states build their registration and license classes around, and a 49.5cc machine and a 150cc machine are not treated the same everywhere. Ask your own DMV which class you are buying into before you pick a number.
The verdict
Buy the Maddog Gen V 150 because you want a Maddog. That is a legitimate reason to spend money, and it is why almost everyone who owns one bought it. The reviews are good, the platform is easy to live with, and the parts supply behind a GY6 is effectively bottomless.
Do not talk yourself into it as a commuter. A cheaper scooter on the same shelf carries more, stops better and will not need its carburetor coaxed after a cold month. And if what you love is the shape rather than the engine, the 49.5cc version wears the identical body for four hundred dollars less.
One honest note from the reviews: a 2024 buyer reported the clear coat lifting early. One report out of nine, and the same person said he wanted another. Look the paint over on arrival.
The full shelf is on Scooters, Mopeds & Trikes — 92 listings, from 49.5cc mopeds up to 300cc fuel-injected machines — and the Maddog family lives in Ice Bear Scooters. Not sure which class you want? Call us at 877-667-6289 and describe the ride you actually take, not the one you are picturing.
