What Size Dirt Bike for a Teenager? Seat Heights and Prices (2026)
- on November 13, 2026
Most teenagers fit a 125cc to 150cc dirt bike with a seat height between 30 and 34 inches. A smaller 13-year-old or a first-time rider does better on a 110cc or an automatic 125cc with a seat near 29 inches. A tall, experienced 16- or 17-year-old can move to a 250cc. Fit the bike to the inseam, not the birthday.
That is the short version. The longer version matters because “teen” covers a rider who has not hit a growth spurt yet and one who is taller than you are. Engine size alone will not sort them out, and the number in the listing title that parents skip past is the one that decides whether the bike gets ridden.
Size the bike to the rider’s legs, not their age
Seat height is the measurement to shop by. Put the rider on the bike in riding boots: the balls of both feet should reach the ground, and the hands should reach the bars and levers without locking the elbows. Flat feet with knees deeply bent means the bike is already too small. Tiptoes on one side only means it is too tall, and a new rider who cannot hold a bike up at a stop will drop it, get frustrated and park it.
Engine size is a poor stand-in for that fit. In our own catalog the 125cc class alone runs from a 29-inch seat on the Apollo Ultramax DB-X6 to a 34-inch seat on the Apollo DB-X18. Same displacement, five inches apart. That gap is the difference between a small 13-year-old and a 16-year-old, which is why two bikes with the same cc on the box can suit completely different riders.
A quick way to get a starting number at home: measure the rider’s inseam in socks, from the floor to the crotch. A beginner is comfortable on a seat at or just under that figure. A rider with a season or two behind them can handle a seat an inch or two above it, because the suspension settles under their weight and they are used to stopping on one foot.
What size dirt bike for a 13, 14 or 15 year old?
These bands are a riding convention, not a rule or a legal standard. Height and experience move a rider up or down a band more than a birthday does.
- •Smaller or first-time teen, often 13: 110cc to 125cc, seat around 29 to 31 inches, automatic or semi-automatic. The Apollo DB-X6, TrailMaster TM23 and Apollo DB-X4 sit here.
- •Average-height teen with some seat time, often 14 or 15: 125cc to 140cc, seat around 32 to 34 inches. This is the widest part of the range and where most of the bikes in the table below land.
- •Tall or experienced teen, often 16 or 17: 140cc to 150cc with a 34-inch-plus seat, or a 250cc if they already ride a manual clutch confidently.
One thing you will notice on our listings: every title carries a Kids, Youth or Adult label. As a rule, dirt bikes of 110cc and under are labeled Kids and the 125cc to 150cc class is labeled Youth. A teenager is almost always shopping in the Youth group, with the smallest riders at the top of Kids and the tallest at the bottom of Adult. If you already know the budget, our guide to what a dirt bike costs for a 10, 12 or 14 year old breaks the prices down by age.
Teen dirt bike sizes and prices
Every bike below is in our dirt bike collection today. The table is sorted by seat height, shortest first, because that is the order a parent should read it in. Seat heights and transmissions are quoted from each listing.
| Model | Engine | Transmission | Seat height | Price |
| Apollo Ultramax DB-X6 | 125cc | Fully automatic | 29″ | $779 |
| TrailMaster TM23 | 124cc | Semi-automatic | 29.3″ | $969 |
| Apollo DB-X4 | 110cc | 4-speed semi-automatic | 30″ | $749 |
| Apollo DB-X5 RFZ | 125cc | 4-speed manual | 30″ | $779 |
| RPS 125S | 124cc | 4-speed manual | 30.5″ | $699 |
| RPS Viper-E | 149cc | 5-speed manual | 32.2″ | $1,179 |
| TrailMaster TM24 | 124cc | 4-speed semi-automatic | 32.7″ | $999 |
| TrailMaster LK140 | 140cc | Manual | 32.9″ | $1,199 |
| Apollo DB-X15 | 125cc | 4-speed manual | 33″ | $799 |
| Apollo Thunder 140 | 140cc | 4-speed manual | 33″ | $999 |
| TrailMaster TM29 | 124cc | Manual | 33.5″ | $1,089 |
| Apollo DB-X18 | 125cc | 4-speed manual | 34″ | $899 |
| Apollo Thunder 150 | 140cc | 4-speed manual | 34.5″ | $999 |
| TrailMaster TM31 Pro 250 | 223cc | 5-speed manual | 34″ | $1,649 |
| Apollo Thunder 250 | 250cc | 5-speed manual | 35.8″ | $1,699 |
Prices and availability as listed on motobuys.com on November 13, 2026. Prices change; the product page is always current.
Read across the rows and the pattern is clear. Under $1,000 you can choose a seat anywhere from 29 to 34.5 inches, so price does not force a size on you. What costs more is equipment: electric start, inverted forks, a fifth gear and a bigger frame.
Automatic, semi-automatic or manual clutch for a teen?
Pick the transmission by experience, not by age. A fully automatic bike is twist-and-go and lets a first-timer learn throttle, braking and balance without stalling. A semi-automatic has a foot shifter but no clutch lever, so the rider learns gears without learning the clutch at the same time. A manual clutch is what most riders end up on, and a teenager who has driven anything with a clutch, or who rides with friends on full-size bikes, will want it from day one.
Our position: a teen who has never ridden should start on an automatic or semi-automatic 125cc, and a teen with any real seat time should go straight to a manual. Buying an automatic for a 15-year-old who already rides is the faster way to an unused bike. The full breakdown is in automatic vs semi-automatic dirt bikes.
Check the starter as well. Several of the manual 125cc bikes above are kick start only, including the Apollo DB-X5 RFZ, RPS 125S and Apollo Thunder 140. A light rider can kick a 125cc over, but it takes technique. The TrailMaster TM23, TM24, TM29 and LK140 have electric start, and for a newer rider restarting on a hill that button is worth more than it sounds.
Can a 16 or 17 year old ride a 250cc dirt bike?
If they are tall enough and already comfortable on a manual clutch, yes. The 250cc-class trail bikes we carry are full-size machines: the TrailMaster TM31 Pro 250 has a 34-inch seat at $1,649 and the Apollo Thunder 250 has a 35.8-inch seat at $1,699. They are sized for adults, and the titles say Adult for that reason. For a teen who has outgrown a 140cc they are the natural next step. For a teen who has never ridden, they are too tall and too heavy to learn on. We go through that decision in is a 250cc dirt bike good for beginners.
Should you buy a dirt bike a teen will grow into?
No. Buy the bike that fits now. A bike that is too tall this year does not get ridden this year, and a rider who is nervous about stopping never builds the confidence that growing into it was supposed to reward. Teenagers do grow fast, so plan for it the sensible way: if the rider is between two seat heights and has some experience, take the taller one. If they are new, take the shorter one. We made the longer case for this in don’t buy the bike they’ll grow into.
What to know before the crate shows up
These bikes arrive in a steel crate, not ready to ride. Expect to fit the front wheel, handlebars, front fender and front plate, add fuel and check the oil before the first start, and go over every bolt with a wrench. A teenager can help, and should: a rider who helped put the bike together is far more likely to notice a loose chain later. Our walkthrough on what to do when a dirt bike arrives in a crate covers the order to do it in.
Every bike in the table is an off-road machine. None of them is set up for the street, so plan on private land or a riding area, and check the age and supervision rules where you plan to ride before you buy. If you would rather talk the sizing through, call 877-667-6289. We sell from our warehouse in Garland, Texas, and can walk you through the assembly options for any bike in the table.
What size dirt bike for a 13 year old?
Most 13-year-olds fit a 110cc to 125cc dirt bike with a seat height of about 29 to 31 inches. A first-time rider is better on an automatic or semi-automatic, such as the Apollo Ultramax DB-X6 or TrailMaster TM23. A tall 13-year-old with experience can ride a 125cc with a 32- to 33-inch seat.
How much is a dirt bike for a 14 year old?
On motobuys.com, the 124cc to 140cc dirt bikes that fit most 14-year-olds are priced from $699 to $1,199 as of November 13, 2026. The price difference mostly buys electric start, upgraded forks and a larger frame, not a different size.
What is a good dirt bike for a 15 year old?
A 125cc to 140cc manual with a 32- to 34-inch seat suits most 15-year-olds. The TrailMaster TM24 is a semi-automatic option with a 32.7-inch seat, and the Apollo Thunder 150 is a manual with a 34.5-inch seat for taller riders. Check the fit with the rider seated in boots.
Are mini dirt bikes good for teens?
Usually not. Mini dirt bikes are built for younger kids, and many have seats around 25 inches or lower, which leaves a teenager cramped with knees above the bars. A small 13-year-old may still fit a 110cc with a 30-inch seat, but most teens need a Youth-size 125cc or larger.
Is a 125cc dirt bike good for beginners?
Yes, for a teenager or a smaller adult. A 125cc four-stroke has manageable power, and the class comes in automatic, semi-automatic and manual versions with seats from 29 to 34 inches. Choose the transmission by experience and the seat height by inseam.
Should a teen start on an automatic or a manual dirt bike?
A teen who has never ridden learns fastest on an automatic or semi-automatic, because there is no clutch to stall. A teen with riding experience should go straight to a manual clutch. Most riders move to a manual eventually, so skipping it only makes sense for a true beginner.
Three teen-size dirt bikes in stock now
Still deciding between two sizes? Browse every bike in Dirt Bikes & Pit Bikes or the full Kids & Teens range, or call 877-667-6289 with the rider’s height and inseam and we will point you to the right seat height.
