The MB200 Mini Bike: Who Should Buy It, and Who Should Buy Something Else
- on August 27, 2026
The most-reviewed machine on this site is not a dirt bike. It is a mini bike — the TrailMaster MB200, 4.8 stars across 40 reviews, and not one of those reviews below four stars. It is also, regularly, the wrong machine for the person asking about it.
That is not a knock on the bike. It is a very good bike. It is a knock on the picture: a mini bike photographs like a small dirt bike, and it is not one. Here is who should buy the MB200, who should buy something else, and the one thing to do before the first ride that nobody puts in the box.
What the MB200 actually is
A 196cc single-cylinder four-stroke on a low, wide steel frame. Recoil start — you pull a cord, like a lawn mower. No clutch lever and no gears: a torque converter feeds power to the chain and you twist the throttle. Front fork shocks, rear hydraulic shock, a rear disc brake, and a headlight that is on whenever the engine is. Off-road only, which is in the title and is not a technicality.
It is a deliberately simple machine. The simplicity is the entire appeal — and it is also exactly where the mismatch happens.
Buy it if
- •Your riding happens on your own land, a trail, or a gravel two-track.
- •You want one machine an adult and a teenager can share without adjusting anything.
- •You would rather never explain a clutch to anybody.
- •You like the shape. Be honest — half of it is the shape.
The reviews are unusually consistent about the thing that actually matters on a small engine: it starts. “It started on the first pull” turns up again and again. On the Hurricane version, one owner put it as “a slight pull on the start handle and your smiling.”
Do not buy it if
This list is longer than the last one, on purpose.
You are buying a first bike for a small child
A mini bike puts a heavy, low, wide frame under a rider and asks nothing of them. A kid’s dirt bike is lighter, taller and has gears, and the gears are the point — learning to use them is the skill. TrailMaster’s own copy on the Hurricane says it flatly: it “is not a good choice for smaller kids.” That line is on the listing for a reason.
You want electric start
You do not get it. Recoil cord only, on all three mini bikes below. If the person riding cannot pull a cord — a bad shoulder, a small kid — that settles the question on its own, and you want an electric-start dirt bike instead.
You want to ride it anywhere near a street sign
Off-road only. There is no version of this bike that is not.
You are in California
Every one of these listings carries the same manufacturer note: not CARB approved. Read that line on the product page, and check your own state’s rules for off-road machines, before you order anything — from us or from anyone.
The hundred-dollar question: MB200 or Hurricane
| Model | Price | Brakes | Suspension | Drive | Rating |
| MB200 | $799 $1,049 | Rear disc | Front and rear | Torque converter | 4.8★ (40) |
| MB200X Hurricane | $899 $1,149 | Hydraulic disc, front and rear | Front and rear | Torque converter | 5.0★ (15) |
| Storm 200 | $519 $649 | Rear disc | None — rigid frame | Centrifugal clutch | 4.5★ (17) |
Same 196cc engine, same torque converter, same suspension on the top two. The difference is one brake. The Hurricane has hydraulic disc at both ends; the MB200 has one at the rear.
Our position: pay the hundred dollars.
A rear-only brake is not dangerous on flat ground, and plenty of people ride the MB200 for years without a second thought. But on any two-wheeler most of the stopping force in a hard stop lives at the front wheel, and a rider who has only ever had a rear brake never learns to use one. Add a downhill and loose gravel and it stops being theoretical. The Hurricane sits at 5.0 stars across 15 reviews and the reviews name the brakes specifically: “Buy it for the safety features, like front and back hydraulic brakes.”
If your budget is fixed at $799, buy the MB200 and enjoy it — it is a genuinely well-liked machine. If your budget flexes by a hundred dollars, this is the best hundred dollars available anywhere in the category.
The trap underneath both of them
The Storm 200 at $519 looks like the same bike for less money. It is not. Same 196cc engine, but a centrifugal clutch instead of a torque converter, and — the part people miss until it arrives — no suspension at all. Rigid frame, and small wheels under it.
It is honest fun for laps around a field at that price. Point it up a hill with an adult on board and the difference shows up immediately: a centrifugal clutch slips and bogs where a torque converter keeps pulling. Its 4.5-star average is the lowest of the three, and that is roughly where it belongs. Buy it knowing what it is, or spend up.
If what you actually wanted was a kid’s dirt bike
Different aisle entirely. We list 96 dirt bikes, and the ones that suit a younger rider look nothing like a mini bike:
- •TM11 — 110cc, fully automatic, electric start, 25-inch seat. $659.
- •TM15 — 107cc, four-speed semi-automatic, 24.4-inch seat. $759.
- •TM23 — 125cc, semi-automatic, electric start, 29.1-inch seat. $939.
Electric start and gears — the two things the mini bike deliberately leaves out. A TM23 owner explains the appeal better than we can: “As a parent I love the electric start. My son loves the semi auto trans so he can stop without a clutch and no shifting.”
One thing to do before the first ride
Check the chain tension. These mini bikes arrive with the chain tight, and it gets tighter as the rear suspension compresses under a rider. An owner said it plainly in a four-star review: it “def needs a spring loaded chain tensioner out of the box as the chain is super tight on these and only gets tighter as the suspension compresses.”
Ten minutes with a wrench before the first ride heads off the most common first-month complaint in the whole category. It is not in the manual and it is not in the box.
The verdict
The MB200 is one of the best-liked machines we sell and it earns that: an adult-and-teen trail bike that starts every time and asks nothing of the rider. It is not a child’s first dirt bike, no matter how the photograph reads. Get that one distinction right and you will be happy with it for years.
Buy the Hurricane if the budget stretches. Check the chain either way.
Browse the full range: dirt bikes & pit bikes. Prices shown as listed at the time of writing.
