Are Side-by-Sides Worth It? The Real Benefits of Owning a UTV
- on December 02, 2022
A UTV earns its price when you regularly move people, tools or material across ground a truck cannot reach and a wheelbarrow makes miserable. If you ride alone, for fun, on tight trails, a quad costs less and does that better. The answer depends less on the machine than on how many loaded trips a week you already make on foot.
What a UTV actually replaces
The useful comparison is not UTV against ATV — that is a different question, covered in our UTV vs ATV comparison. It is a UTV against the workarounds you use now.
- •The wheelbarrow. A cargo bed rated for a few hundred pounds does in one trip what takes eight or ten by hand: feed, fence posts, firewood, gravel, a chainsaw and a gas can, all at once.
- •The truck that does not fit. A full-size pickup is roughly 80 inches wide. Most value-tier side-by-sides sit in the 48–60 inch range, which is the difference between driving a gate, an orchard row or a trail and walking it.
- •The truck you would rather not sink. Wet pasture, soft creek crossings and rutted two-track strand a road vehicle and barely trouble a light UTV.
- •The second beater vehicle. An old truck kept only for chores still costs registration, insurance, tires and batteries. A UTV that never leaves the property usually costs none of that.
If you are still working out what the category covers, start with our plain-English explanation of what a UTV is, then come back for the ownership math.
Two seats change what the machine is for
This is the benefit people underrate. A quad carries a rider. A side-by-side carries a passenger in a real seat, with a belt, inside a roll cage, with a floor under their feet. That one difference turns a piece of equipment into a vehicle the rest of the household will actually use — a spouse to open gates, a kid who comes along instead of being left behind, a helper who arrives at the job with you rather than walking.
Cargo works the same way. A rear bed, especially a dump bed, means you stop planning trips around what will balance on a rack.
It is a year-round machine, which a quad is not
Sitting in a cab with a roof and a windshield rather than straddling a seat changes the weather you are willing to work in. Winter feeding, spring mud, fall hunting and summer heat are all more tolerable with shade overhead and your boots on a floor instead of in the spray.
Be realistic about traction. Most value-tier machines are two-wheel drive or use a high/low gear rather than true four-wheel drive. Deep snow, standing mud and steep wet grades are where selectable 4WD stops being a luxury. If that is your property, budget for a 4x4 model instead of adding tires to a 2WD one and hoping.
What it honestly costs to own
| Cost | What to expect |
| Purchase | Roughly $3,000 for a basic two-seat model up to about $11,000 for a four-seat, 4x4 or electric machine. |
| Storage | It needs a covered spot — a shed bay, or at minimum a fitted cover. Sun and standing water kill seats, plastics and wiring faster than use does. |
| Insurance | Usually not required on private property. Worth pricing anyway; rates vary by state and carrier, so ask rather than assume. |
| Fuel | Small single-cylinder engines. Normal property use is a few gallons a week. Electric models trade that for overnight charging. |
| Routine service | Oil and filter every 50–100 hours or once a season, plus air filter, valve lash and drive checks. |
| Wear items | Drive belt, brake pads, battery, tires. Belts and batteries are what strand people, so keep a spare belt. |
| Assembly | Crate machines need final assembly and a first service. Budget shop time or an afternoon with the manual. |
Resale, honestly
Value-tier machines depreciate faster in percentage terms than premium brands. That is the trade for a lower entry price. What holds value is condition and paperwork: a clean, running machine with service records and unbroken plastics sells quickly, because the used market between roughly $3,000 and $6,000 is thin and buyers there look hard. Keep the receipts, keep it covered, replace the belt before it fails, and wash the mud off the radiator.
Machines worth looking at
When the answer is no
- •You ride alone on tight, technical trails. A quad is narrower, lighter and more fun there for less money.
- •Your use is almost entirely farm work. Priorities shift to bed capacity and low-range gearing — see our guide to the best UTV for farm work.
- •It is mainly for the kids. Size, speed limiting and supervision matter more than capability; our kids side-by-side safety guide covers what to require.
- •You have nowhere to store it. Solve that first.
For everyone else — a few acres, a household that will all use it, and a chore list that currently involves carrying things — a UTV is one of the few powersports purchases that pays part of itself back in saved trips.
Are side-by-sides worth it for a small property?
On five acres or more with regular hauling, usually yes. Under an acre with paved access, a garden cart and a truck cover most of it. The break-even is loaded trips per week, not acreage.
What is a UTV used for besides trail riding?
Hauling feed, firewood, gravel, tools and fencing; moving people around a property; hunting access; snow clearing; and reaching places a full-size vehicle cannot fit.
Do I need insurance for a UTV?
In most states, not if it stays on private property. It becomes a real question if you trailer to public riding areas. Requirements vary by state, so ask your carrier.
How much maintenance does a UTV need?
Less than most people expect. Oil and filter every 50 to 100 hours or once a season, plus air filter, tire pressure, brake and belt checks.
Is a UTV cheaper than keeping an old truck for property work?
Often, because a UTV that never leaves your land avoids registration, road insurance and road-legal repairs. Upfront cost is higher; running cost is usually lower.
