What Is a Utility Task Vehicle (UTV)? A Plain-English Guide
- on May 04, 2023
A utility task vehicle — UTV, or side-by-side — is an off-road machine with side-by-side seating, a steering wheel, seat belts, a roll cage and a cargo bed. That last part is what separates it from an ATV: a UTV is built to carry things and people, not just a rider.
What is a utility task vehicle?
The category name is literal. These are vehicles built to perform tasks — hauling feed, pulling a trailer, moving tools across a property, getting a hunting party and their gear somewhere a truck cannot go. Recreation came later and is now half the market, but the design brief is still work.
You will see the same machines called UTVs, side-by-sides, SxS, or utility vehicles. They mean the same thing. "Utility task vehicle" is simply the formal version.
UTV vs ATV: the practical differences
| UTV / side-by-side | ATV / quad | |
| Seating | Side by side, 2 to 6 people | Straddle, usually 1 rider |
| Controls | Steering wheel and pedals | Handlebars and thumb throttle |
| Safety | Roll cage, seat belts, doors or nets | Rider skill and body position |
| Cargo | Dedicated bed, often dumping | Racks front and rear |
| Towing | Typically 1,000 lb and up | Typically several hundred pounds |
| Terrain | Wider, needs more trail room | Narrower, fits tighter trails |
| Learning curve | Shallow if you can drive a car | Steeper, needs body input |
What people actually use them for
- •Property work. Moving feed, fencing materials, firewood and tools around acreage.
- •Farm and ranch. Checking fence lines, hauling, light towing, all-weather access.
- •Hunting. Quiet access, gear capacity and a way to get game back out.
- •Recreation. Trail riding with passengers, which an ATV cannot really offer.
- •Grounds maintenance. Golf-cart-style models handle campuses, resorts and large yards.
How to size one
| Engine | Realistic use |
| 150 – 200cc | Flat to rolling ground, light loads, recreation |
| 300cc | Hills, heavier loads, longer days |
| 450cc and up | Real utility work, towing, four-wheel drive terrain |
| Electric | Quiet operation, predictable short routes, low maintenance |
The most common sizing error is buying the cheapest machine for a job that needs torque. If the vehicle will regularly climb hills carrying weight, start at 300cc.
What to check before buying
- •Seats. Two or four — you cannot add a row afterwards.
- •Fuel injection. Worth paying for in cold climates and at altitude.
- •High/low range and 4WD. Only present on larger models, and genuinely needed for loaded hill work.
- •Delivery. These arrive crated by freight. Plan how it comes off the truck.
- •Assembly. Choose a pre-assembled option where offered, or budget for setup.
Machines to start from
Trailmaster Challenger 200 (2 Seater) 169cc UTV Live Rear Axle
2 seat, recreation entry point
$3,299$3,599
TrailMaster Challenger 4-200EX (4 Seater) UTV side-by-side Great Family Fun
4 seat, fuel injected
$5,499$5,899
Trailmaster Taurus 450-U UTV High/Low Gear- 4 wheel Drive (2 Seater)
450cc, 4WD, high/low gear
$8,699$10,439
ViewFrequently asked questions
A UTV is an off-road vehicle with side-by-side seating, a steering wheel, seat belts, a roll cage and a cargo bed. It is built to carry people and loads across rough ground.
What is the difference between a UTV and an ATV?
A UTV seats people side by side with a steering wheel, roll cage and cargo bed. An ATV is straddled by a single rider using handlebars. UTVs carry more; ATVs fit narrower trails.
What size UTV do I need for work?
For genuine utility work — towing, hauling, hills — start at 300cc and look for high/low range. Machines of 150–200cc suit recreation and light loads on flatter ground.
Are UTVs street legal?
In most places, no. Some states and counties allow limited road use with equipment such as lights, mirrors and a slow-moving-vehicle sign. Check your local rules before buying.
How much can a UTV tow?
Full-size utility machines commonly tow around 1,000 lb or more, but capacity varies widely by model. Check the specification for the exact machine rather than assuming.
