Buying an Adult ATV as a Gift: Sizing, Type and Timing
- on August 07, 2023
If you are buying an ATV for an adult, the two things that decide whether it gets ridden are physical fit and intended use — not horsepower. A full-grown adult will not be comfortable on a mid-size quad regardless of engine size, and a quad bought for weekend trail riding is set up very differently from one bought to haul feed around a property.
Adult quads start where youth quads stop
Plenty of quads in the 110cc to 125cc range get described as suitable for adults. In practice they are built around a teenager: shorter seat height, narrower track, lower weight capacity. An average adult can sit on one, but the suspension is at its limit and the machine feels twitchy. For a sense of how modest that performance is, see how fast a 125cc quad goes.
Adult-fit machines generally start around 150cc to 170cc, with a taller seat, a wider stance and a chassis rated for adult weight plus cargo. That is the honest floor for a grown rider.
| Engine size | Who it fits | What it handles well |
| 110–125cc | Teens and very small adults | Flat ground and slow loops; an adult outgrows it quickly |
| 150–170cc | Adult beginners | Light trails, property chores, a genuine first quad |
| 200cc | Most adult recreation | Trail riding, reaching a hunting spot, light hauling |
| 250–300cc | Riders with some experience | Longer rides, rougher terrain; 4x4 for mud and grades |
Utility quad or sport quad?
This is the choice most gift buyers skip, and it matters more than the engine. Look at what the recipient already does outdoors rather than at what looks fast.
- •Utility quad — front and rear racks, a hitch, upright seating, softer power delivery, wider stance. Right for property owners, hunters, anyone who will strap something to it.
- •Sport-style quad — narrower, lower, quicker steering, no racks. Right for someone who wants to ride trails for the sake of riding.
- •4x4 — worth the money only if there is real mud, sand or grade involved. On dry trails it mostly adds weight and cost.
If they talk about carrying tools, passengers or gear more than about riding, a side-by-side may suit them better than a quad. We compared the two in UTV vs ATV.
The hard part: it is a surprise purchase
A quad is one of the few gifts where the wrong size cannot be quietly fixed. It arrives crated on a freight pallet, and sending it back is slow and expensive. A few ways to de-risk it:
- •Get their height and rough inseam from someone who can ask without giving it away, and check them against the seat height on the product page.
- •If they have never ridden, choose the smaller, softer engine. An intimidating first quad gets parked; a slightly slow one gets ridden every weekend and traded up later.
- •Read the return and freight policy before you order, not after.
- •Consider gifting the decision instead of the machine: wrap the helmet and a printout of two or three models, and let them pick size and color.
Adult quads worth shortlisting
Four machines covering the usual range of adult gift budgets, from a first quad to a 4x4.
For a wider price picture across the category, see what four-wheelers actually cost. Shopping for a younger rider instead? The sizing rules are different, and they are covered in our guide to buying an ATV as a gift for a kid.
Budget for gear, not just the quad
Plan on a few hundred dollars beyond the machine. A DOT-rated helmet, goggles, gloves and over-the-ankle boots are the minimum, and buying them as part of the gift removes the excuse to ride without them — our riding gear guide covers necessary versus optional. Add fuel, oil for the first service, and a battery tender if the quad will sit for weeks between rides.
Freight and assembly: what actually shows up
Quads in this class ship crated on a pallet by freight carrier, not by parcel. Somebody has to be at the delivery address to receive it, and a garage or driveway with room to uncrate helps. Assembly varies: some models arrive largely pre-assembled and need handlebars, front wheels and a battery connection, while others take a couple of hours and a torque wrench.
If the quad has to arrive by a specific date, order well ahead. Freight scheduling is the part you do not control, and it is the most common reason a machine misses the day it was meant to be given on. Once it is uncrated, how to ride an ATV walks a new rider through the first few hours.
What size ATV is right for an adult?
Fit first: an adult wants a full-size chassis with an adult seat height and stance, which generally means 150cc or larger. Smaller displacement is built around a teenage rider.
Is a 125cc ATV big enough for an adult?
Only for a small adult on flat, slow ground. A 125cc quad is designed around teenage weight and dimensions, so ride quality, braking and stability were not engineered for an adult load.
Should I buy a utility or sport quad as a gift?
Match it to what the person already does. If they own land, hunt, or will carry tools, buy the utility layout with racks and a hitch. If they simply want to ride trails, a lighter sport-style quad is more fun and usually cheaper.
How much should I budget beyond the ATV itself?
Set aside a few hundred dollars for a DOT helmet, goggles, gloves and boots, plus fuel, oil for the first service and a battery tender. Gear bought with the machine tends to actually get worn.
Can I return an ATV if it is the wrong size?
Sometimes, but it is expensive and slow because the machine ships crated by freight. Check the return policy before ordering, and if fit is uncertain, gift the choice rather than the machine.
