How Fast Does a 125cc Four-Wheeler Go?
- on April 03, 2024
Most 125cc four wheelers top out somewhere around 30 to 38 mph. Nearly all of them ship with an adjustable speed limiter, so the number that matters is not the ceiling — it is where you set the screw on day one.
This question usually comes from a parent, and the honest answer is that the top speed is the least useful spec on the page. A 125cc quad with the limiter wound in is slower than a 70cc without one. What you are really buying is headroom.
Typical top speeds by engine size
These are the ranges commonly reported for youth and entry-level quads in this class. Individual machines vary with gearing, weight and tire size — treat this as a guide, not a specification.
| Engine | Typical top speed | Usually suits | Limiter fitted? |
| 50–70cc | 15–25 mph | First-time young riders | Almost always |
| 110cc | 28–33 mph | Ages roughly 8–12 | Almost always |
| 125cc | 30–38 mph | Ages roughly 10–14 | Almost always |
| 150–170cc | 40–50 mph | Teens and small adults | Sometimes |
| 200cc+ | 50–55 mph | Adults | Rarely |
Why two 125cc quads are not the same speed
Displacement sets a ceiling. Everything else decides where the machine actually lands under it.
- •Gearing. A quad geared for torque climbs better and tops out lower. Same engine, different number.
- •Weight. Both the machine's and the rider's. A heavier rider costs several mph.
- •Tire diameter. Bigger wheels raise the effective gearing and the top speed.
- •Terrain. The published figure assumes hard flat ground. Grass, sand and hills take a large bite.
- •Engine type. A four-stroke air-cooled 125 behaves differently from a tuned one, even at identical displacement.
Choosing by speed is the wrong approach
Parents ask about top speed because it is the one number that sounds like it measures safety. It does not. What actually decides whether a machine is safe for your child is whether they can reach the controls, get both feet down, and stop it.
Size the quad to the rider first, set the limiter second, and let the top speed be whatever it turns out to be. A machine that fits and is limited is safer at 38 mph than one that does not fit is at 20.
Three quads across the range
See all ATVs and four wheelers, or narrow to kids and teens vehicles. Call 877-667-6289 if you want help matching a machine to a specific rider — the phone reaches our Garland, Texas warehouse.
How fast does a 125cc four wheeler go?
Most 125cc youth quads run about 30 to 38 mph unrestricted. Nearly all of them ship with an adjustable speed limiter that can bring that down to walking pace, which is how most of them are actually delivered to a new rider.
How fast is a 110cc ATV compared to a 125cc?
The gap is smaller than the numbers suggest, usually a few miles per hour. A 110cc typically tops out around 28 to 33 mph. Weight, gearing and tire size move the figure as much as displacement does.
Can you make a 125cc quad faster?
Backing the speed limiter out is the intended way and needs no parts. Beyond that you are into sprockets, exhausts and jetting, which void the warranty and rarely give back what they cost on a machine this size.
Is 125cc too fast for a child?
Not with the limiter set correctly. A 125cc with the screw wound in is slower than an unrestricted 70cc, and it gives your child somewhere to grow into. That is the argument for buying one over a smaller machine.
What decides an ATV's top speed?
Displacement sets the ceiling, but gearing, weight, tire diameter, terrain and the rider all move the real number. Two 125cc quads from different makers will not match.
Working out the budget as well as the size? Our pricing guide by age covers what these machines cost at each size.
