Dirt Bikes for Adults: A Gift Buyer's Guide
- on October 06, 2023
A dirt bike is a great gift and a bad surprise. The machine has to fit the rider’s body and skill level, and neither is something you can guess from across the room. The way to do this well is to decide the bike with the recipient and keep the gift itself — that you are buying it — the surprise.
Why sizing an adult bike as a blind surprise goes wrong
With most gifts a bad guess is an inconvenience; with a dirt bike it is a safety problem. Too tall and the rider cannot dab a foot down on an off-camber stop. Too powerful and the throttle gets away from them the first time they open it in second gear. An adult who has never ridden will not know which applies to them.
Adults also have opinions about brand, wheel size, and road-legal versus off-road only — and returning a crated machine is nothing like returning a sweater.
Three ways to de-risk it
- •Gift the decision, not the machine. Wrap a helmet, a set of gear, and a note that the bike is theirs to choose. The surprise lands, and the rider picks the fit.
- •Measure quietly. If you want a full surprise, get the inseam — not the height — from a pair of their pants, and size to that. Inseam is what determines whether they can reach the ground.
- •Ask what they have ridden. Someone who rode as a teenager is a different buyer than someone who never has. Past experience moves the sensible engine size up a full class.
Sizing an adult dirt bike
Seat height is the number that matters, and it varies far more than displacement. Full-size adult bikes sit between 34″ and 38″. Seated, a rider should get the balls of both feet down — flat feet means the bike is small, tiptoes on one side means it is tall.
| Rider height | Inseam | Seat height to look for | Notes |
| 5’0″–5’5″ | 27″–30″ | 31″–34″ | Big-wheel 125s and small 150s fit better than a full-size 250 |
| 5’6″–5’10″ | 30″–32″ | 34″–36″ | The mainstream adult range; most 250s land here |
| 5’11″ and up | 32″+ | 36″–38″ | Taller 250s and 300s; a short bike will cramp the knees |
How much engine an adult beginner needs
The instinct is to buy big so they do not outgrow it. Resist it — a bike that intimidates its rider gets ridden twice and then sits.
| Displacement | Who it is for | Reality check |
| 125cc–150cc | First-ever adult rider, tight property riding | Plenty for learning; a confident rider will want more within a season |
| 200cc–250cc | The default adult choice | Enough for trails and open ground, still forgiving. Most adults should start here |
| 300cc+ | Riders with real experience | Fast, heavier, less patient with mistakes. Not a first bike |
Be honest about where it will be ridden, too. With no land and no nearby riding area, the gift becomes a machine in a garage.
Gear to buy alongside it
Gear is part of the purchase, not an accessory. If the budget is tight, buy a smaller bike and better gear rather than the reverse.
- •Helmet — a DOT-rated MX helmet, fitted. This is the one item worth spending on.
- •Goggles — separate from the helmet on an MX lid, and necessary the moment there is dust.
- •Boots — over-the-ankle motocross boots. Ankles are the most common injury on a first ride.
- •Gloves and a jersey — cheap, and they save skin.
- •Chest and knee protection — worth it for a beginner who will pick the bike up more than once.
Delivery and assembly: plan backward from the date
Full-size dirt bikes ship freight in a crate, and freight schedules are less predictable than parcel. If the bike has to be there on a specific day, order well ahead and treat the delivery estimate as an estimate.
Plan for a curbside liftgate delivery and a way to move a crate weighing a couple hundred pounds. Assembly is typically bars, front wheel, fender, fluids, and a full bolt check — a couple of hours with hand tools, or a short shop visit. Electric-start batteries usually need charging before first start, and the bike should be re-torqued after the first two rides.
If timing is tight, give the helmet on the day and let the bike arrive later — better than a crate that misses the date.
Four adult bikes worth considering
These span the sensible range, from an entry-level full-size to a machine that expects experience.
The short version
Size to inseam, not height. Start at 250cc unless the rider has real experience. Buy the gear at the same time, and order early enough that freight has room to be late. If there is any doubt about fit, make the gift the gear and let the rider choose the bike.
What size dirt bike should an adult get?
Match seat height to inseam, not overall height. Adults between 5’6″ and 5’10″ usually fit a 34″–36″ seat, where most 250s sit. Shorter adults are happier on a big-wheel 125 or a 150.
Is a dirt bike a good gift for an adult?
It is, as long as the rider helps choose the size. The safe version is to gift the helmet and gear as the surprise and pick the bike together.
What is a good first dirt bike for an adult beginner?
A 200cc–250cc four-stroke with electric start and a seat height that lets them touch down — forgiving to learn on, capable enough not to be outgrown in a month.
Do adult dirt bikes come assembled?
Most arrive crated and mostly assembled, needing bars, front wheel, fluids, a battery charge, and a bolt check. Budget a couple of hours or a short shop visit.
How long does dirt bike delivery take?
Full-size bikes move by freight, so transit runs from days to a couple of weeks depending on distance and carrier schedules. If it must arrive by a set date, order with a wide margin.
