Best Dirt Bike for a Kid's Gift: Size, Gear and Timing
- on October 06, 2023
The gift goes wrong in one of two ways: the bike is too big, or it shows up in a crate on the morning it was supposed to be ridden. Pick the size from the rider’s inseam rather than their age, budget a few hundred dollars for a helmet and gear on top of the bike, and order four to six weeks early so it arrives, gets built and gets hidden.
Size it to the rider, not to the birthday
Seat height decides whether a bike gets ridden. A new rider should be able to sit on the seat and touch the ground with the balls of both feet — flat-footed is even better for the first season. If they have to tiptoe, the bike tips over at every stop, and a bike that scares a kid at walking pace does not get a second outing.
| Age | Typical height | Seat height | Engine | Transmission |
| 4–6 | 3’2”–3’9” | 17–21 in | 50–60cc | Automatic, training wheels available |
| 6–9 | 3’8”–4’3” | 21–25 in | 70–110cc | Automatic |
| 9–12 | 4’2”–4’10” | 25–29 in | 110–125cc | Automatic or semi-automatic |
| 12–15 | 4’10”–5’6” | 29–33 in | 125–150cc | Semi-automatic or 4-speed manual |
Treat those as a starting point, not a rule — kids of the same age vary by a foot. For the full method, including how to measure inseam and when to size up, see our full youth dirt bike sizing guide.
Automatic, semi-automatic or manual
For a gift, automatic is almost always right. There is no clutch and nothing to shift, so the rider spends their attention on balance, throttle control and looking where they are going. Semi-automatic adds a foot shifter but keeps the automatic clutch — a good second step. A full manual is for a rider who already rides well. Electric start is also worth the small premium: a kick-start engine a child cannot start alone turns every ride into a request for help.
Bikes by age
For the size that suits most 8 to 12 year olds, see 110cc dirt bikes.
For a quieter first bike that suits a smaller yard, see our electric dirt bikes.
Budget for the gear, not just the bike
Gear is not optional and it is not cheap. Buy it with the bike, so the child can actually ride on day one.
| Item | Typical cost | Why it matters |
| Helmet (DOT youth) | $60–150 | Non-negotiable. Fit it in person if you can; a loose helmet is nearly useless |
| Goggles | $20–40 | Dust and roost in the eyes ends rides fast |
| Gloves | $20–35 | Hands go down first in every low-speed tip-over |
| Boots | $80–180 | Protect ankles from the footpeg and the bike falling over |
| Chest protector | $50–100 | Worth it once they leave the flat yard |
| Knee and elbow pads | $30–60 | Cheap, and the difference between a scrape and a bad day |
Plan on roughly $250 to $500 for a full set. If money is tight, spend it on the helmet and the boots first.
Timing, so it arrives built and not in a crate
Powersports vehicles move by freight, not parcel, and freight does not behave like a package. Work backward from the date.
- •Order four to six weeks out. Processing plus freight transit is commonly one to three weeks, and December is the slowest stretch of the year on the freight network.
- •Expect a delivery appointment. Most carriers call to schedule and leave the crate at the curb. Someone needs to be home, and you need a second person to move it.
- •Budget two to four hours to build it. Crated bikes typically arrive 80 to 90 percent assembled and need the front wheel, handlebars, fluids and a battery charge. Mostly pre-assembled options exist if you would rather not.
- •Start it before the day. Charge the battery, check the oil and run the engine once. Finding a problem in advance beats finding it in front of an excited eight-year-old.
- •Hide the crate, not the bike. Build it in a garage or at a neighbor’s, then roll it out finished.
Setting expectations with the child
The first ride is slower and shorter than anyone imagines, and that is fine. Most youth bikes have a throttle limiter screw — turn it most of the way in for the first sessions and back it out as skill builds. Start in a flat, open area with no trees and no slope, walk alongside for the first laps, and stop while they still want more.
Set the rules before the keys change hands: gear on every time, an adult present, agreed boundaries, and the bike stays off until an adult says otherwise. Rules given with the gift are accepted far more easily than rules added later — and it helps to say plainly that the way to earn a bigger bike is to ride the small one well.
What is the best dirt bike for a kid as a gift?
The one that fits. For most first-time riders that is an automatic 50cc to 110cc bike with a seat height the child can reach with the balls of both feet, plus electric start so they can start it alone.
What size dirt bike for a 5 year old?
Usually a 50cc or 60cc automatic with a seat height around 17 to 21 inches, often with removable training wheels. Measure the child rather than going by age.
How much should I budget beyond the bike?
Roughly $250 to $500 for a helmet, goggles, gloves, boots and pads. If the budget is tight, buy the helmet and boots first and add the rest later.
How early should I order so it arrives in time?
Four to six weeks. Vehicles ship by freight with a delivery appointment, and transit slows in December. Order early enough to build and test it before the day.
Does it arrive fully assembled?
Usually not. Crated bikes commonly arrive 80 to 90 percent assembled and need the front wheel, handlebars, fluids and a charged battery — two to four hours of work. Mostly pre-assembled options are available.
