Dune Buggy Accessories: What To Add First and Why
- on May 04, 2023
Buy dune buggy accessories in order of what they protect: first the people, then the machine, then comfort, then looks. That order gets a buggy trail-ready for less money than a light bar and a set of whips, and it stops you buying twice.
A new buggy arrives ready to ride and needs nothing to work. Everything here is an add-on. Before you order any of it, check your own spec sheet — plenty of models already ship with a bimini top, a windshield, mirrors, a utility rack or a trailer hitch, and buying a second one is the most common wasted purchase in this category.
This guide is only about parts you bolt on. Getting the most out of what your buggy already has — shocks, tires, seat position, gearing — is a separate job, covered in our dune buggy setup and tuning guide.
The buying order
| Accessory | What it does | Check before you buy |
| Harness upgrade | Holds you in the seat over rough ground | Mounting points and belt width; 4-point vs 5-point |
| Skid plate, A-arm guards | Protects the belly pan and suspension from rocks | Model-specific fit; added weight |
| Grab handles, footrests | Gives passengers something to hold and brace against | Frame tube diameter; clamp or weld-on |
| Mirrors | Lets you see riders behind you in a group | Tube clamp size; folding if you trailer the buggy |
| Lighting | Extends riding into dusk and dark | Charging system capacity; fuse and relay |
| Roof or bimini top | Sun and light rain protection | Whether one is already fitted; cage spacing |
| Windshield | Blocks sand, dust and branches | Full, half or vented; vented reduces back-draft dust |
| Cargo rack, corner bags | Carries gear without filling the cabin | Published load limit; keep weight low |
| Cover | Protects paint, seats and dash when parked | All-weather rating with sun protection |
Lighting
Stock headlights are sized for the machine, not for fast night riding. A bar or a pair of pods on the cage transforms visibility, and whip lights on the rear make you visible to other vehicles in dunes and open desert — which is a safety item, not decoration.
The catch is electrical. These buggies run a 12-volt system specified for stock lighting, and stacking a large bar plus whips plus a stereo can outrun what the charging system replaces. Wire accessories through a fused relay from the battery rather than splicing into the existing harness, keep total draw modest, and check after a long ride that the battery is still charging rather than slowly draining.
Roofs, tops and windshields
A bimini top is the cheapest comfort upgrade there is, and on a long summer day it is the difference between finishing a ride and cutting it short. A hard roof adds noise protection and better rain cover at more weight and cost. Confirm the spacing of your cage tubes before ordering either.
Windshields come full, half or vented. A full windshield keeps the most dust and brush off, but on an open buggy it can create a back-draft that pulls dust in behind you; a vented shield lets air through and largely stops that. Whatever you fit, use a polycarbonate panel rather than acrylic, which cracks.
Mirrors, grab handles and footrests
These are the cheapest accessories on the list and the ones owners regret skipping. A wide-view center mirror or a pair of clamp-on side mirrors matters as soon as you ride in a group. Grab handles and footrests, usually aluminum clamp-ons, give a passenger something to hold and brace against so they are not steadying themselves on the cage or on you. Fit them before a long trip, not after.
Cargo and storage
Most buggies have a rear utility rack from the factory. Add-ons that work with it are tie-down straps, a weatherproof cargo bag, and corner bags that strap to the tube frame for the small items you want to reach without stopping — tools, water, a first-aid kit. Respect the rack's published load limit, and keep heavy weight low rather than piled high.
Seats and harnesses
If you upgrade one thing for safety, upgrade the restraint. Many buggies ship with four-point belts; a five-point harness adds an anti-submarine strap that keeps you from sliding forward under braking. Bucket or racing seats are a real comfort improvement on long rides, and they usually mount on the existing rails — but confirm that before ordering, because seat brackets are model-specific and racing seats often arrive with no instructions at all. If the mounting is not obvious, have a shop do it. A seat is not the place to improvise.
Protection and storage
A skid plate and A-arm guards pay for themselves the first time you find a rock, and they are worth fitting before you go looking for rough ground rather than after. At the other end, an all-weather cover with a sun rating protects seats, dash plastics and paint whenever the machine is parked outside — and dune buggies are open vehicles, so there is nothing else keeping weather out of the cabin.
Buggies with a lot already included
Whatever you bolt on, it adds to the list of things that need checking. Our DIY dune buggy maintenance guide covers the routine that keeps hardware, wiring and cage bolts from working loose.
What accessories should I buy for a dune buggy first?
Restraint and protection before comfort and looks: a proper harness, a skid plate and guards, then grab handles and mirrors. Lighting, tops and sound come after that.
Do I need a windshield on a dune buggy?
Not strictly, but it keeps sand, dust and branches out of your face. A vented shield is usually the better choice on an open buggy, because a solid one can pull dust in behind it.
Can I add a light bar to my buggy?
Yes, but wire it through a fused relay direct to the battery and keep the total draw reasonable. These machines have a 12-volt system sized for stock lighting, and a large bar plus whips can outrun the charging system.
Will racing seats fit my buggy?
Often, but seat brackets are model-specific and racing seats frequently ship without instructions. Confirm the mounting before ordering, and use a shop if it is not straightforward.
Do I need a cover if my buggy is in a garage?
Still useful. A cover keeps dust off the seats and dash between rides, and you will want one anyway for trips where the buggy sits outside overnight.
