110cc Dirt Bike Guide: What Age It Fits, Seat Heights and Prices (2026)
- on November 23, 2026
A 110cc dirt bike fits most kids from about 7 to 13, but the engine size alone will not tell you which kid. The 110-class bikes we stock today sit anywhere from 24.4 to 31.5 inches at the seat and cost $599 to $1,249. Pick by seat height and gearbox first, then price.
That seven-inch spread is the part most guides skip. They quote one seat-height range for “a 110” and name no models, or they give an age bracket with no measurements behind it. Below are the actual bikes, sorted by seat height, with today’s prices. Use the table to rule bikes out, then read the two sections after it.
What age is a 110cc dirt bike for?
There are really two bikes hiding under one label, and the age answer is different for each.
- •Small-frame 110s: 10- or 12-inch front wheel, seat around 24 to 25 inches. By convention these suit riders of roughly 7 to 10. Most are the first “real” bike after a 50cc or 70cc starter.
- •Big-wheel 110s: 14-inch front wheel, seat from 28 to about 30.5 inches. These suit riders of roughly 10 to 13, or a shorter teen. They have the same engine in a taller, longer chassis.
Treat those ages as a rule of thumb, not a rating. No table can see your kid. A tall eight-year-old with a year on a 70 belongs on a different bike than a cautious eleven-year-old who has never ridden, and both of them are “110 age.” Inseam and experience decide it. The age only gets you to the right row.
How tall is a 110cc dirt bike? Seat heights and prices, November 23, 2026
Every bike in this table is active and in stock today, pulled from our live catalog. One thing a spec sheet shows that a title does not: most bikes sold as “110” actually displace 107cc. It is the same engine family and it changes nothing about how they ride. The engine column shows what each maker states.
| Model | Engine | Gearbox / start | Front wheel | Seat height | Price |
| TrailMaster TM10 | 107cc | Semi-auto 4-speed, kick | 10 in | 24.4 in | $599 |
| TrailMaster TM11 | 107cc | Automatic, electric | 10 in | 24.4 in | $599 |
| TrailMaster TM15 | 107cc | Semi-auto 4-speed, electric | 12 in | 24.4 in | $699 |
| Apollo DB-28 | 110cc | Automatic, electric | 12 in | 25 in | $649 |
| TrailMaster JHL SK110A | 107cc | Automatic, electric | 12 in | 25 in | $849 |
| TrailMaster JHL SK110E | 107cc, fuel injected | Automatic, electric | 12 in | 25 in | $1,069 |
| Tao DB14 | 110cc | Semi-auto, kick | 14 in | 28 in | $699 |
| TrailMaster JHL MK110-ES | 107cc, fuel injected | Semi-auto 4-speed, electric | 14 in | 29.6 in | $1,249 |
| Apollo DB-X4 | 110cc | Semi-auto 4-speed, kick | 14 in | 30 in | $749 |
| Apollo DB-32 | 110cc | Semi-auto 4-speed, kick | 14 in | 30.5 in | $649 |
| RPS 110DLX | 107cc | Semi-auto 4-speed, kick | 14 in | 30.5 in | $699 |
| RPS 110S | 107cc | Automatic, electric | 12 in | 31.5 in | $679 |
Prices and availability as of November 23, 2026. Seat heights are the spec-sheet figures with no rider aboard; listing titles round to the nearest inch, so a bike titled 25-inch may read 24.4 on its spec sheet. Open each product page for the full specification.
Three things stand out. First, paying more does not buy you height: $599 gets a 24.4-inch seat and $649 gets a 30.5-inch one. The extra money in this class goes to fuel injection and electric start. Second, every 14-inch-wheel bike in stock today is a semi-automatic. Third, the tallest seat in the table belongs to a 12-inch-wheel bike, the RPS 110S at 31.5 inches, which is why you read the seat-height line and not the wheel size.
See the whole group on the 110cc dirt bikes collection, or the wider kids dirt bikes range.
Automatic or semi-automatic 110?
On a 110 this choice matters as much as height. A fully automatic bike has no gears to think about: twist and go. A semi-automatic has a four-speed gearbox the rider shifts with a foot lever, but no clutch lever to stall it with. Neither one in this class has a hand clutch.
For a first-time rider, go automatic. The TrailMaster TM11 at $599 is the obvious starting point: electric start, the lowest seat in the class, and a 5.0 rating from 12 reviews. For a kid who has already outgrown a 70 and can ride, a semi-automatic is the better buy, because it teaches shifting before the 125 adds a clutch. The TrailMaster TM15 (4.6 from 10 reviews, $699) and the kick-start TM10 (4.56 from 9 reviews, $599) are the small-frame options.
Here is the catch for taller beginners. If your rider needs the height of a big-wheel bike but is not ready to shift, the choice narrows fast: the RPS 110S is the only fully automatic 110 in stock today with a seat above 25 inches. We go deeper on the trade-off in automatic vs semi-automatic dirt bikes.
How much does a 110cc dirt bike cost?
Between $599 and $1,249 new on our site today. The carbureted bikes from TrailMaster, Apollo, Tao and RPS run $599 to $849. Fuel injection starts at $1,069 with the TrailMaster JHL SK110E and tops out with the big-wheel MK110-ES at $1,249.
Is fuel injection worth roughly $200 more than the carbureted version of the same bike? For a bike that will sit for weeks between rides and then get started by a parent in a cold garage, we think yes. For a family that rides every weekend and does not mind a choke lever, the carbureted bike does the same job for less.
Budget for two things the price tag leaves out: a helmet and boots that fit, and assembly. These bikes come crated from our Garland, Texas warehouse, partly assembled, with the final assembly and a full fastener check left to do. If you would rather not do that yourself, ask about our assembly service when you order. If you would, read the first two hours with a crated bike before you open it.
70cc, 110cc or 125cc: which step is right?
Parents often assume the 70 is the small bike and the 110 is the bigger one. Check the spec sheets. The Apollo DB-25 70cc ($649, automatic) has a 25-inch seat, the same as the small-frame 110s. Moving from that 70 to a TM11 gets your kid more engine, not more room. If they have outgrown the 70 physically, they need a big-wheel 110, not a small one.
The truly smaller bike is a step below that: the TrailMaster TM06 60cc at $449 has a 22-inch seat and removable training wheels. That is the bike for a five- or six-year-old who cannot yet flat-foot a 24-inch seat. The rest of that class is on the 60cc and 70cc dirt bikes page.
Going up, a 125 overlaps the big-wheel 110 in size. The RPS 125S sits at 30.5 inches and costs $699, exactly what the 110DLX costs. What changes is the gearbox: it is a four-speed manual with a real clutch. So the question at that point is not size. It is whether your rider is ready for a clutch. Our 125cc seat height guide has that table, and the bikes are on the 125cc dirt bikes page.
How to check the fit before you order
- •Measure inseam in riding boots. Crotch to floor, standing straight. Compare it with the seat-height column, remembering the suspension settles a little once a rider sits down.
- •Use the flat-foot test. A new rider should get the balls of both feet down while seated. A confident rider can manage with one foot flat.
- •Do not buy a bike to grow into. A kid who cannot touch the ground cannot save a tip-over, and one bad drop in the first week ends a lot of riding careers.
- •Check the listed max load if an older sibling or a parent will ride it too. It varies a lot inside this class, from 132 lb on the RPS 110S to 220 lb on the Apollo DB-32.
Roughly 7 to 13, depending on the frame. Small-frame 110s with a 24- to 25-inch seat suit riders of about 7 to 10. Big-wheel 110s with a 28- to 30.5-inch seat suit riders of about 10 to 13. That is a convention based on fit, not an official rating. Go by inseam and experience.
How tall is a 110 dirt bike?
It depends on the model. The 110-class dirt bikes we stock range from 24.4 to 31.5 inches at the seat. Bikes with 10- or 12-inch front wheels mostly sit at 24 to 25 inches; bikes with a 14-inch front wheel sit at 28 to 30.5 inches.
New 110cc dirt bikes on Motobuys cost $599 to $1,249 as of November 23, 2026. Carbureted models run $599 to $849 and fuel-injected models start at $1,069.
Are there automatic dirt bikes?
Yes. In the 110 class alone we stock several fully automatic bikes, including the TrailMaster TM11, Apollo DB-28 and RPS 110S. Others are four-speed semi-automatics, which shift with a foot lever but have no clutch lever. Check the gearbox line on the listing.
What size dirt bike for a 13 year old?
Usually a big-wheel 110 or a 125, with a seat between about 28 and 31.5 inches. Go by inseam, not birthday: the rider should get the balls of both feet on the ground while seated. A 13-year-old who already shifts gears is normally ready for a 125 with a clutch.
What is the smallest dirt bike for kids?
Among the kids’ dirt bikes we stock that state a seat height, the lowest is the TrailMaster TM06 60cc at 22 inches, with removable training wheels, priced at $449. The small-frame 110s start at 24.4 inches.
Three 110s worth a look
Not sure which frame size your rider needs? Call 877-667-6289 with their inseam and what they ride now, and we will tell you which rows of the table to ignore. Or browse all dirt bikes and pit bikes.
