What Is Considered High Mileage for a Motorcycle?
- on May 30, 2024
There is no single number. 20,000 miles is high for a 50cc scooter and barely run-in for a touring bike. What actually predicts how much life is left is the service history, not the odometer — a documented 40,000-mile bike beats a neglected 12,000-mile one every time.
People ask this hoping for a threshold. There isn't one, and the reason matters: these machines are engineered to completely different duty cycles. Judging them all against one number will make you overpay for some bikes and walk away from good ones.
What counts as high mileage, by type
| Machine type | Ordinary mileage | Getting high | Why |
| 50cc scooter / moped | 5,000–15,000 | 20,000+ | Small engines, high revs, light components |
| 150–250cc scooter | 10,000–25,000 | 30,000+ | Built for commuting, still small components |
| Mid-size street bike | 20,000–40,000 | 50,000+ | Robust engines, well-supported parts |
| Large touring bike | 40,000–80,000 | 100,000+ | Designed for continuous distance |
| Dirt bike | Hours, not miles | — | Engine hours and rebuild history are the real measure |
Dirt bikes are the outlier: many have no odometer at all, and hours plus rebuild history tell you far more than distance would.
Why service history beats the odometer
A motorcycle engine wears from heat cycles, dirty oil and neglect far more than from distance covered. That is why the two bikes people compare most often — low miles that sat, versus high miles that were ridden and serviced — usually favor the second.
What to check on a high-mileage bike
- •Service records. First thing, and if there are none, assume the worst and price accordingly.
- •Chain and sprockets. Hooked teeth and a tight-spot chain tell you how the whole bike was treated.
- •Tire date codes. Not tread depth — the date. Old tires are hard and dangerous regardless of how they look.
- •Fork seals and coolant. Weeping seals and rusty coolant are both cheap to see and expensive to ignore.
- •Whether the engine has been opened. Not automatically bad — a documented rebuild can be a plus. An undocumented one is not.
When new beats used
If you are weighing a high-mileage used bike against a new budget machine, the honest comparison is not the odometer against zero. It is a known machine with a warranty against someone else's maintenance decisions at a lower price.
A used premium bike that was genuinely looked after is often the better machine. A used bike with no history at a tempting price is a gamble, and the repair that follows tends to erase the saving.
What a new budget machine costs instead
Browse motorcycles, dual sports and enduros or scooters and mopeds. Financing is available. Call 877-667-6289 — our Garland, Texas warehouse.
What is considered high mileage for a motorcycle?
It depends on the type. For a small-displacement scooter or moped, 20,000 miles is a lot. For a mid-size street bike, 30,000 to 50,000 is ordinary and well-maintained examples run far beyond it. For a large touring bike, 50,000 miles is barely broken in.
Is 20,000 miles a lot for a motorcycle?
On a 50cc scooter, yes. On a 600cc street bike, no — that is early middle age. The same odometer reading means completely different things depending on what it is attached to.
Does mileage or age matter more?
Maintenance history beats both. A 40,000-mile bike with every service documented is a better buy than a 12,000-mile bike that sat outside for four years with old fluids in it.
What should I check on a high-mileage motorcycle?
Service records first. Then chain and sprockets, tire dates, fork seals, coolant condition, and whether the engine has been opened. Cosmetics tell you how it was treated; fluids tell you whether it was maintained.
Is a high-mileage used bike better value than a new budget bike?
Sometimes. A well-kept used bike from a premium maker can outlast a new budget machine. But you are buying someone else's maintenance decisions, and on a used bike there is no warranty behind that gamble.
Choosing between engine sizes rather than mileage? Our moped vs scooter comparison explains what each class can legally and practically do.
