Best Kids ATV: How to Shortlist a Youth Quad Worth Buying
- on December 02, 2022
The best kids ATV is the smallest one your child can control confidently, with brakes on all four wheels, a tether kill switch and an adjustable throttle limiter. Those three parts are what separate a quad you can supervise from one you cannot. Everything else — graphics, engine size, brand — matters far less than most buyers assume.
Shortlist by ruling machines out
Do not start from a list of best sellers. Start with a fit that works, then eliminate. Sizing by age and height is its own subject and we cover it properly in our youth ATV sizing guide, including the reach-and-stand test. Assume you have done that and have a size class in mind. From there, four filters remove most of the market fast.
- •No tether kill switch, no sale. A lanyard that kills the engine when the child separates from the machine is the single most useful safety part on a youth quad. Many cheap imports omit it or fit a dummy.
- •No adjustable throttle limiter, no sale. A screw stop on the throttle housing lets you set a beginner speed and open it up over months. Without one you buy the whole speed range on day one.
- •Rear brake only, no sale. Rear-only braking teaches bad habits and stops badly downhill. Look for brakes at all four wheels, or at minimum a proper front pair plus rear.
- •No parts channel, no sale. Covered below, and it is the filter people skip.
What separates a good youth quad from a bad one
| Feature | What good looks like | Why it matters |
| Brakes | Discs or drums at all four wheels, with a foot brake as well as levers | Rear-only setups skid and lengthen stopping distance on loose ground and slopes |
| Kill switch | Tether lanyard clipped to the rider, plus a handlebar stop | Stops the machine the instant the child comes off, not when they remember the lever |
| Speed control | Threaded throttle limiter you can set with a screwdriver | Lets one quad grow with a rider over two or three seasons |
| Suspension | Real coil-over shocks with visible travel front and rear | Rigid or token suspension beats up a light rider and costs control on ruts |
| Transmission | Automatic, ideally with reverse | Reverse saves a child from having to drag a stuck quad backward alone |
| Frame and guards | Full nerf bars or footwell guards, chain fully covered | Keeps feet away from the rear wheels and the drive chain |
Electric or gas
Electric youth quads have gotten genuinely good, and for young beginners on a small property they can be the better call. They are quiet, so you can talk to your child while they ride. They start with a key rather than a pull. And there is no fuel, oil or carburetor to go stale over winter.
Gas still wins on run time and range. A charged electric quad gives a fixed session and then stops for hours; a gas one takes two minutes and a can. Gas also has a deeper used parts supply. If the riding is short bursts in a yard, go electric. If it is a full afternoon on acreage or riding with an adult on a trail, go gas.
New or used
Used youth quads are tempting because kids outgrow them quickly, which means clean low-hour machines exist. The risk is that the previous owner removed the limiter, lost the tether key, or ran it hard on a neglected air filter. Buy used only if you can start it cold, check that all four brakes bite, confirm the limiter screw is present, and see clean oil on the dipstick.
Buy new when you want the warranty, the correct tether keys and a parts channel that will still answer in two years. On value-tier machines the price gap between a good used example and a new one is often small enough that new wins.
Parts and support, the filter nobody applies
A youth quad is a consumable. It will need a chain, sprockets, brake pads, a battery, levers and probably a plastic panel after someone tips it into a fence. The question that decides whether the machine is still running in year three is whether you can buy those parts without hunting overseas listings. Before you order, check that the seller stocks parts for that model, that the manual exists in English, and that the model line has been sold long enough for parts to be common.
Quads that pass these filters
Whichever you choose, spend the first few sessions on skills rather than speed — our guide to beginner ATV riding techniques covers what to teach first. If your child will be riding with a sibling or a friend, also read our kids side-by-side safety guide, since a two-seat machine changes the supervision picture entirely.
Once you have a size in mind, the two biggest youth classes are grouped as 125cc four wheelers and 110cc four wheelers.
What is the best ATV for kids?
The best one is the smallest machine your child can control with confidence, fitted with all-wheel brakes, a tether kill switch and an adjustable throttle limiter. Fit and controls decide the answer, not engine size.
Is 125cc too big for a kid?
Not by itself. A 125cc automatic with the limiter set low is often calmer than a smaller machine with no limiter. What matters is seat height, weight and whether the child can reach the controls and put their feet down.
Should I buy an electric or gas kids ATV?
Electric for short sessions in a yard, quiet operation and no seasonal fuel maintenance. Gas for long run times, acreage and a deeper used parts supply.
Are used kids ATVs a good deal?
Sometimes. Kids outgrow them quickly so low-hour machines exist, but check that the throttle limiter is still fitted, the tether key is present and all four brakes work before buying.
What safety gear does a child need?
A DOT or youth-rated helmet that fits snugly, goggles, gloves, over-the-ankle boots and long sleeves. Chest and knee protection are worth adding as speeds increase.
