Adult Trikes: Layouts, 150cc Top Speed and What to Check
- on January 16, 2024
A 150cc adult trike is a three-wheeled scooter, and on flat ground with an average rider it will realistically run somewhere around 40 to 50 mph, not the 60-plus a 150cc two-wheeler might see. The extra wheel, the extra 100-plus pounds and the wider frontal area all cost speed. What you buy instead is a machine that stands up by itself at every stop.
Tadpole or delta: the two layouts
Every three-wheeler is one of two shapes, and the difference is not cosmetic.
| Layout | Wheels | Behavior | Common examples |
| Delta | One front, two rear | Simple and inexpensive, big rear storage and towing capacity, more likely to lift an inside wheel in a fast turn | Most trike scooters, including the Ice Bear Q6, Trifecta and Maddog trikes |
| Tadpole | Two front, one rear | Two contact patches doing the steering and most of the braking, so it stays more planted in corners and under hard stops | Can-Am Ryker style machines and the Vitacci X200 Tryker |
A delta trike with a solid rear axle drags the inside wheel through tight turns and scrubs tires. A differential in the rear axle lets the wheels turn at different speeds and is worth looking for on the spec sheet. Neither layout leans. You steer a trike the way you steer a car, and the countersteering habit a motorcyclist has is exactly the wrong input.
How fast is a 150cc trike, really?
Published top speeds assume a light rider, flat ground and no wind. Real numbers land lower, and a trike carries more weight and more drag than the same engine on two wheels.
| Engine | Realistic top speed | What it suits |
| 49–50cc | 30–35 mph | Neighborhood and campus errands; a moped class in many states |
| 150cc | 40–50 mph | Town riding and 45 mph roads; short highway stretches are not its job |
| 200cc, fuel injected | 50–60 mph | Longer commutes and hillier ground with a heavier rider |
Who a trike actually suits
- •Riders who dislike stops. A trike does not need to be held up at a light, on gravel, or on a slope. For many people that single fact is the whole reason.
- •Older and returning riders. Balance, knee and hip issues make a two-wheeler tiring long before they make it unsafe. A trike removes that problem.
- •People who want to carry things. Delta trikes have a real trunk, and most take a light tow hitch.
- •New riders on a budget. An automatic CVT means no clutch and no gears to learn.
Who it does not suit: anyone who wants the feel of a motorcycle. A trike does not lean, will not carve, and rewards braking in a straight line before the corner rather than trailing brakes into it. It is also not automatically safer. It will not fall over at a stop, but it is wider than a bike, less able to change line mid-corner, and the rear wheels track differently through a rut.
License, helmet and registration rules
These vary by state and are the part most buyers skip. Some states treat a three-wheeler as a motorcycle and require a full motorcycle endorsement; others issue a three-wheel-only endorsement; a few classify certain machines as autocycles that a regular driver license covers. Helmet requirements are separate and vary again, as does whether a 50cc machine registers as a moped with lighter requirements. Check your own state DMV before you buy, not after delivery.
One more paperwork item: a street-legal trike needs a title or manufacturer's certificate of origin to register. Confirm that the seller supplies one, and check whether the model is CARB approved if you live in California.
What to check before you buy
- •Brakes. Discs front and rear. A drum rear on a 500-pound machine is a meaningful downgrade.
- •Rear axle. A differential rather than a solid axle, for tire wear and tight turns.
- •Fueling. Fuel injection starts more reliably in the cold and drifts less than a carburetor.
- •Weight capacity and seat height. Rated capacity commonly falls in the 320 to 440 pound range; check it against rider, passenger and cargo.
- •Assembly. These arrive crated with the rear wheels, fenders, windshield, mirrors and battery to install. Budget the time or pay for assembled delivery.
- •Parts. Most of these use the GY6 engine family, which is the best-supported small engine in the country. That is a genuine advantage for repairs.
Trikes worth a look
Icebear Q6 150cc Trike PST150-17
Ice Bear Q6 150cc trike, differential rear axle, windshield and trunk
$2,699$3,239
ICE BEAR TRIFECTA 150cc Trikes PST150-2
Ice Bear Trifecta 150cc, disc brakes, tow hitch, under-seat storage
$2,599$3,119
ViewPrices shown at time of writing. Street-legal status, CARB approval and assembly requirements differ by model, so read the individual listing.
The honest summary
A value-tier 150cc trike is a good town machine and a poor highway machine. It will cruise comfortably in the 35 to 45 mph range, carry a trunk of groceries, start on a button and cost very little to run. It will not keep up with traffic at 65, and buying one expecting that ends badly. If your riding is errands, back roads and short hops, that trade is fine. If you need to merge onto an interstate, buy more engine.
What is the top speed of a 150cc Ice Bear trike?
Realistically about 40 to 50 mph on flat ground. Rider weight, a passenger, wind and hills all pull that down. Trike scooters are heavier than two-wheel scooters with the same engine, so they run slower.
What is the Ice Bear Q6?
The Q6 is a 150cc delta trike scooter with two rear wheels, a differential rear axle, disc brakes front and rear, automatic CVT transmission, a full windshield and a locking trunk. A 50cc version is also sold.
Do you need a motorcycle license to ride a trike?
It depends on the state. Some require a full motorcycle endorsement, some issue a three-wheel-only endorsement, and some classify certain three-wheelers as autocycles covered by a regular driver license. Check your state DMV.
What is the difference between a tadpole and a delta trike?
A tadpole has two wheels in front and one at the rear, which improves cornering and braking stability. A delta has one wheel in front and two at the rear, which is simpler, cheaper and better for cargo.
Are trikes safer than motorcycles?
They will not fall over at a stop, which removes a common low-speed accident. They are wider, do not lean, and cannot change line mid-corner the way a bike can, so they trade one set of risks for another.
