Fall Is the Best Riding Weather of the Year. Everyone Quits Anyway.
- on September 24, 2026
Every fall, riders make the same mistake: they put the machine away right when the weather finally gets good enough to enjoy it.
There’s a reason for that mistake. Summer feels like riding season because it’s when everyone else is riding — pools closing, school starting, an unspoken sense that once the leaves turn, it’s over. It isn’t. Cooler air is denser air, and denser air means more oxygen per stroke of the engine, which is part of why a lot of carbureted machines that felt sluggish and rich-running in summer heat wake up once the mornings turn crisp. Add trails that have finally firmed up after being blown to dust all summer, no bugs in your teeth at speed, and woods that open up once the underbrush dies back, and you get some of the best conditions of the year arriving right when most people quit.
For anyone using a machine for actual work — checking a property line, hauling feed to a stand, getting equipment to the back of a lease before the two-track turns to soup — fall is when a real 4x4 with low-range gearing stops being a nice-to-have. That’s a different job than a summer trail lap, and it calls for a different machine.
Three Machines That Get Better as the Temperature Drops
These are the three we’d point you to right now, depending on what your fall actually looks like.
For hunting land and property work — TrailMaster Taurus 450-U
A shaft-driven 390.8cc UTV with genuine 4x4, high and low range, and front and rear differential lock isn’t overkill for an October farm road — it’s closer to the minimum. This is the one to buy if your fall involves getting equipment, feed, or a deer somewhere the truck can’t follow. It’s not the one to buy if you just want to run laps on cleared trail; for that, keep reading. Owners have it rated 4.8 out of 5 so far.
For adult trail riders stretching the season — RPS Blizzard 200 Sport
A full-size automatic ATV with a 177.3cc engine, electric start, and a reverse gear you’ll actually use backing out of a trailhead. This is the one for someone who wants a real month or two more of trail time before the ground turns to mud or snow, without fussing with a clutch to get it. It carries a 4.5-star rating from the owners who’ve reviewed it.
For one more real dirt bike season — TrailMaster TM33-250
A full-size 223cc frame with a 5-speed manual transmission and both electric and kick start, built for a rider who’s outgrown a mini bike and wants an actual trail machine, not a toy with a bigger sticker. It’s sized and geared for someone who already knows how to ride, and it’s currently sitting at a perfect 5-star rating from the owners who’ve weighed in.
One Thing Nobody Tells You About Cold Mornings
The first properly cold morning of the season is when CVT belts on automatic UTVs and ATVs get loud — a squeal or a rough engagement off idle that goes away once the belt and clutch weights warm through the first stretch of easy riding. It isn’t a defect. It’s just what a rubber belt does before it warms up, and it’s the single most common “is something wrong with my machine” question we hear once the weather turns. Give it a slow first stretch before you ask it to actually work.
If You’re Already Seeing Frost, This Is Prep Time, Not Riding Time
Everything above assumes you’ve still got real ridable weeks ahead. If you’re somewhere the ground is already freezing overnight, don’t wait for the first snow to think about storage. Run fresh fuel with stabilizer through the tank rather than letting old gas sit all winter, hook up a battery tender instead of finding a dead battery in the spring, and bump tire pressure up a bit so a machine that sits for months doesn’t develop a flat spot. Doing this on a mild fall afternoon is a quick job. Doing it in a cold garage after the battery’s already dead takes a lot longer, and usually costs more.
If you’re not in that kind of climate — and most of the country isn’t — none of that applies to you yet. Riders in milder climates are just getting into their best stretch of the year. Ignore the calendar and keep riding.
Whichever category you’re in, don’t let “it’s basically fall” talk you out of a season that, for a lot of these machines, is just getting good.
Browse the full lineup: UTVs & Side-by-Sides, ATVs & 4 Wheelers, and Dirt Bikes & Pit Bikes.
