Dirt Bike vs Enduro: Weights, Differences and Which to Buy
- on July 08, 2024
A dirt bike is built to go fast over short, groomed circuits. An enduro is built to survive long days over unpredictable ground, which is why it carries a bigger tank, softer power, a headlight and roughly 20–50 more pounds. The weight difference is the clearest way to tell the two apart.
How much does a dirt bike weigh?
This is the question most people actually arrive with, so here it is first. Weights below are approximate ready-to-ride figures — the machine with fluids in it, which is what matters when you have to pick it up off the ground.
| Class | Typical engine | Ready-to-ride weight |
| Youth / pit bike | 50 – 125cc | 90 – 165 lb |
| Motocross, 2-stroke | 125cc | 195 – 210 lb |
| Motocross, 4-stroke | 250cc | 220 – 235 lb |
| Motocross, 4-stroke | 450cc | 235 – 250 lb |
| Enduro | 250 – 350cc | 240 – 255 lb |
| Enduro | 450 – 500cc | 250 – 265 lb |
| Dual-sport (street legal) | 250 – 650cc | 270 – 350 lb |
Manufacturers quote weight differently — some dry, some without fuel. Treat any single published number as a ballpark and compare like with like.
The short version: a 250 dirt bike weighs around 220–235 lb and a 450 lands near 240–250 lb. An enduro of the same displacement is usually 10–25 lb heavier because of the tank, lighting, kickstand and heavier-duty parts.
Dirt bike vs enduro: the real differences
| Motocross / dirt bike | Enduro | |
| Designed for | 20–35 minute races on a closed track | Multi-hour rides over varied terrain |
| Power delivery | Aggressive, peaky, rewards revs | Broader and softer down low |
| Gearbox | Close ratios, usually 5 speed | Wider ratios, often 6 speed |
| Suspension | Stiff, tuned for big jumps | Plusher, tuned for rocks and roots |
| Fuel tank | Small — roughly 2 gallons | Larger — 2.5 gallons and up |
| Lights / kickstand | Usually none | Standard |
| Street legal | No | Sometimes, depending on model and state |
| Weight | Lighter | 10–25 lb heavier |
What about cross-country?
Cross-country bikes sit between the two. They keep motocross-style aggression but add an enduro's wider gearbox and bigger tank. If you ride fast on open trails rather than tight technical ground, that middle category is often the right answer.
Which one should you buy?
Choose a motocross-style dirt bike if
- •You ride a track, a practice field, or your own property.
- •Sessions are short and you trailer the bike to them.
- •You want the lightest machine for the money.
- •Street legality is irrelevant to you.
Choose an enduro if
- •You ride trails for hours at a time.
- •You need range between fuel stops.
- •The terrain is technical — rocks, roots, hills, mud.
- •You want lights and the option of plating the bike in some states.
Starter bikes worth a look
The 250s we stock, off-road and dual-sport, are grouped under 250cc dirt bikes.
A 250cc four-stroke motocross bike is typically 220–235 lb ready to ride, and a 450 is around 235–250 lb. Youth and pit bikes run 90–165 lb, and street-legal dual-sports can reach 350 lb.
How much does a 250 dirt bike weigh?
Roughly 220–235 lb with fluids for a four-stroke motocross model. A 250 enduro of the same displacement is usually 10–25 lb heavier.
What is the difference between a dirt bike and an enduro?
A dirt bike is tuned for short races on a closed track: light, stiff and aggressive. An enduro is built for long rides over varied terrain, with a bigger tank, softer power, wider gearing, lights and more weight.
Is an enduro heavier than a motocross bike?
Yes, typically by 10–25 lb at the same engine size, because of the larger fuel tank, lighting, kickstand and heavier-duty components.
What is the difference between enduro and motocross bikes?
Motocross bikes are made for 20–35 minute races on groomed circuits. Enduro bikes are made to keep going for hours over unpredictable ground, so everything is geared toward endurance rather than lap time.
