Family UTVs: Four-Seat Side-by-Sides With Kids Aboard
- on October 19, 2023
A family UTV is a machine an adult drives with children riding as passengers — a completely different buying problem from a youth machine a child drives. What matters is whether a child physically fits the seat and restraint, how many seats you truly need, and how the machine changes once it carries people who cannot brace themselves.
Passenger is not the same as driver
If your child will be the one driving, the sizing, speed limits and supervision rules are different, and we cover them in kids side-by-side safety and what age a kid can drive a side-by-side. This guide is about the other case: a full-size side-by-side that a licensed adult drives, with kids belted in beside or behind them.
That distinction matters because a full-size UTV is not scaled down for a child. The seat, belt geometry, handholds and cage were designed around adult dimensions, so whether a child can ride safely depends on whether they fit that space, not on their age.
The passenger fit test
Manufacturers publish a version of the same fit check, and it is worth doing in person before you buy. Seated normally, the passenger should be able to:
- •Sit with their back flat against the seat back, without sliding forward.
- •Place both feet flat on the floor of the machine.
- •Grip the passenger handhold or grab bar comfortably with the belt fastened.
- •Keep the shoulder belt across the middle of the shoulder, not the neck or off the arm.
If a child cannot do all four, they are too small for that machine. Cushions and booster seats do not fix it — they change how the restraint loads the body. Passenger rules also vary by state and riding area, so confirm them where you ride.
What changes when the machine carries a family
| Two-seat | Four-seat | |
| Length | Shorter, easier on tight trails | Noticeably longer, wider turning circle |
| Weight | Lighter, stops sooner | Heavier loaded, longer braking distance |
| Cargo | Usually a real bed | Bed shrinks or disappears |
| Storage | Fits most garage bays | Measure before you buy |
| Price | Lower | Typically several thousand more |
| Best for | Couples, work, one passenger | Two adults plus two kids, on the same ride |
Be honest about how often all four seats will be full; a four-seat machine used two-up most weekends is length and money carried for nothing. TrailMaster splits its range into the recreation-focused Challenger family and the utility-focused Taurus family — Challenger vs Taurus explains which side suits family riding.
Restraints, nets and doors
These are the features that separate a machine you would put a child in from one you would not.
- •Belts. Three-point belts are common; four-point harnesses hold a smaller body more securely. Check the belt adjusts to fit a child, not just an adult.
- •Doors or nets. Something must keep arms and legs inside. Nets are light and effective; hard doors add weather protection and weight. An open side is wrong with kids aboard.
- •Handholds. Every passenger seat needs one in easy reach, so a child is not grabbing the cage or the driver.
- •Roll cage and mirrors. Check the cage fully covers the rear seats and that you can see the back row.
Speed and how you drive with kids aboard
Children cannot anticipate or brace the way an adult passenger does, so your driving has to change:
- •Use whatever speed limiting the machine offers — a governor, limiter or restricted key — and set it low until you know how the kids handle it.
- •Brake earlier and turn more gently. A loaded four-seat machine carries more momentum than the same chassis empty.
- •Take side slopes seriously. Extra rear weight changes how the machine feels on a camber.
- •Keep rides short at first. Kids get cold and tired faster than adults, and a tired passenger stops holding on.
- •Helmets and eye protection for everyone, every time, including the short trip around the property.
Four-seat machines to shortlist
TrailMaster Challenger 4-200EX (4 Seater) UTV side-by-side Great Family Fun
Four seats, recreation layout
$5,499$5,899
TrailMaster Challenger 4-300 EFI (4 Seater)
Larger fuel-injected engine, four seats
$5,799$6,199
TrailMaster Challenger 4-300X EFI (4 Seater) UTV Chrome Rims
Four seats with roof, light bar and full cage
$6,699$6,999
ViewFor budgeting across the category, see the side-by-side price guide, and for a straight look at ownership costs and trade-offs, whether a side-by-side is worth it.
Set the rules before the first ride
Agree the ground rules before the machine moves: hands and feet stay inside, belts stay on until the engine is off, nobody gets in or out without the driver saying so, and the driver stops the moment a passenger asks. Do a slow lap first so everyone knows what the machine feels like.
How do I know if my child is big enough to ride as a passenger?
Use the fit check: back flat against the seat, both feet flat on the floor, a comfortable grip on the handhold, and the shoulder belt across the middle of the shoulder. If any of those fail, the child is too small for that machine.
Do I need a four-seat UTV for a family?
Only if all four seats will regularly be occupied. A four-seat machine is longer, heavier, pricier and usually gives up cargo space. Families who ride two-up most of the time are better served by a two-seater.
Are net doors enough, or do I need hard doors?
Nets do the important job of keeping arms and legs inside the cage. Hard doors add weather protection and weight. What matters is that no seat is left open.
Should I limit the speed with kids on board?
Yes. Use the machine's governor, limiter or restricted key and start low. Children cannot brace for bumps the way an adult can, and a slower ride is the one they will want to repeat.
Can kids legally ride as passengers in a UTV?
Passenger age and size rules vary by state and by riding area, and some places set a minimum age. Check the rules for where you will actually ride before your first trip.
